1990 Front End Alignment Question
Just install a 6” Suspension Lift and have Caster Camber Problems, how can I adjust this so I can get it to the front end shop for an alignment?
1990 FS Bronco w/Rough Country Lift
Thanks
I got mine close enough (alignment shop was only 3miles) with the broom stick/measuring tape method... Didn't adjust the toe, just camber... was good enough for me and hope that it works for you.
Is this done from the top ball Joint adjustment and can you give me a quick idea of how to adjust this bushing?
Thanks
PM Sent to JatT
Thanks for the idea... Here's a new How-To article...
BB Alingment
Depending on how far you need to go, set all the ecentrics to center, set to to 1/4" in, and tighten down everything.
If you can find a shop near you who will work on lifted trucks(not all will), if wilkesboro isnt too far you can bring it too me. We do lift kits on anything nissan and have a nice new machine from hunter.
Thanks for all the help everyone. I adjusted the Toe last night and the Caster/Camber looks perfect now, well enough to drive it to the front end shop.
Thanks:beer:
  Steering shaft Extension Question??? Broncitis 4 2,672 04-17-2015, 02:27 PM
  Front shock mounts snipes243 14 3,572 03-01-2015, 07:51 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 3,535 01-11-2014, 12:26 AM
  Exhaust question Casey835 27 6,429 08-16-2013, 06:03 PM
  Grinding sound from rear end area when driving Crawdad 10 4,178 02-09-2013, 09:33 PM
  1991 351W EFI Question Crawdad 4 1,902 03-27-2012, 09:05 AM
  Rear end vibration 73Bronc 12 2,937 11-13-2011, 01:27 PM
Last Post: cam coffee
  Hard top Question 744x4 5 4,019 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Charleston Alignment Shop BucknEB 1 797 09-02-2011, 03:32 PM
  Tire question dixieboyz13 12 4,200 08-25-2011, 01:58 PM
Last Post: ncsubronc
