Not mine--- Good stash of parts on Charleston Craigslist
https://charleston.craigslist.org/pts/5498140921.html
$150 - Fiberglass grill, never installed.
$250 - Fiberglass "Cowl Induction" Hood by Rocky Roads, never installed. One piece, unfinished underside, will need to use hood pins. Also included are the BC Broncos Fiberglass Hood Strut Kit.
$200 - Long Link Dual Traction Bar set (James Duff "old school"). It was never installed, but the blue powder coat metal parts were sloppily spray painted over by the previous owner. Sold as-is. All hardware is present, according to the directions.
$200 - Used Ford 9" Diff, 3.50, Trac-Loc, 31 spline. Condition unknown, turns freely. Verified 35:10 gear teeth count and 31 spline teeth count. Sold as-as.
$225 - 2-piece Canvas Doors Kit (by Galen years ago), never installed. (You will need the "Roadster" fiberglass inserts)
$325 - Rear Disk Brake conversion kit (BC Broncos), big bearing w/ 1.75" offset. Missing one bolt for the caliper bracket. One of the disks has some surface rust on the mounting surface (see photo). You need to verify which bearings and offset for your particular Bronco! Never installed.
$50 - Soft top windshield bracket and channel. "Low profile", much better looking than the tall ugly "high rise" ones. Also much quicker to install and remove the soft top. I think this has been drilled to fit all years of windshields (see photo). Used, great shape.
$50 - Used Baja Hitch, great condition. Works great with a stock bumper, and when the ball is removed, it is a very useful step for accessing a roof rack!
$50 - Aux Heater Assembly, 8.5" x 12.5", 6" tall.
$50 -- Front Tow Bar
$50 -- Ramsey Pro 9000 Winch -- Needs new motor and solenoids. What you see is what you get, sold as-is.
$50 - Tuffy Security Box. NOT THE GLOVE BOX. This is a little bigger, 10"x6"x15". Used, excellent condition.
$1200 - NV 3550 5 speed Transmission with adapters adapters. I believe this is everything needed for the conversion, but look over the photos and verify for yourself. What you see is what you get, sold as-is. The bell housing and D20 adapters have some machining marks and minor nicks, but I believe this is normal, just part of the manufacturing process. Just a FYI.
-Used NV3550. I bought it from a junkyard years ago, they said it was from a wrecked TJ with 33,000 miles. Unsure which year, maybe the id numbers can indicate (see photos). Never re-installed, sold as-is.
- NV 3500 Ford bell housing adapter kit, never installed.
- NV 3500 Dana 20 adapter kit, never installed.
- NV 3500 Bronco crossmember kit, never installed.
- NV 3500 shifter kit. I can't remember if this was bronco specific, I can't find the paperwork. The handle may need to be bent for Bronco installation???
$200 - Dana 20 T-shift, rebuilt (by Jeff's Bronco Graveyard) , never installed. What you see is what you get, sold as-is.
Several sweet thangs on that list I'd Love to have for the 74 but as Super Cell is just around the corner I better hold on to the cash for now.
Some great deals! I'm thinking about the diff as a spare. Are you getting out of the Bronco business or just cleaning house?
Not my stuff, just came across it on CL and passing it on. I haven't been in the Bronco business in way too long Sad
I saw this today as well. Was looking at the hood as the nose of mine is rusted out, but I'm not sure that I like the cowls over where the air boxes are. Its a good deal as it would probably cost just that in shipping to get one here from one of the vendors. I wish I had the money to get the NV3550 setup as that seems to be a great upgrade, just cant swing it right now.
He had those parts listed on classic. Said that a lot of it might be spoken for by locals. All of it sounded like a deal!
Hello everyone, I am the guy with those parts for sale. Sorry, I posted them on ClassicBroncos.com and Craigslist, but totally forgot about posting on this site too! I am located in Savannah, GA. A lot has sold already. I will try to get some photos up here tomorrow or Tuesday. Here is what I have left:
  • $200 - Long Link Dual Traction Bar set (James Duff "old school"). It was never installed, but the blue powder coat metal parts were sloppily spray painted over by the previous owner. Sold as-is. All hardware is present, according to the directions.
  • $200 - Used Ford 9" Diff, 3.50, Trac-Loc, 31 spline. Condition unknown, turns freely. Verified 35:10 gear teeth count and 31 spline teeth count. Sold as-as.
  • $50 - Soft top windshield bracket and channel. "Low profile", I think these were made by Kayline. Much better looking than the tall ugly "high rise" BestTop risers. Also much quicker to install and remove the soft top. I think this has been drilled to fit all years of windshields (see photo). Used, great shape. You will need a "drop back" for the wipers if you have a stock wiper system.
  • $50 - Used Baja Hitch, great condition. Works great with a stock bumper, and when the ball is removed, it is a very useful step for accessing a roof rack!
  • $50 - Aux Heater Assembly, 8.5" x 12.5", 6" tall.
  • $50 -- Front Tow Bar
  • $SOLD$ - NV 3550 5 speed Transmission with adapters adapters. I believe this is everything needed for the conversion, but look over the photos and verify for yourself. What you see is what you get, sold as-is. The bell housing and D20 adapters have some machining marks and minor nicks, but I believe this is normal, just part of the manufacturing process. Just a FYI.
Thanks!
I forgot to mention, it is all "pick-up only", I am not shipping at this time. Thank you!
chuzie Wrote:Are you getting out of the Bronco business or just cleaning house?
I am temporarily getting out of the Classic Bronco hobby :crying:, but I hope to be able to get back into it in another 3 or 4 years.
Just sold the NV3550.
  New 4 Point TBP cage kit on Charleston Craigslist $250--- not mine ncsubronc 2 1,524 08-12-2016, 07:37 AM
  Good Hardtop Jbass 5 2,084 03-10-2016, 10:59 PM
  good aux side fuel tank blazinchuck 1 2,642 06-18-2015, 06:52 PM
Last Post: dixieboyz13
  Early Bronco Parts broncosbybart 29 12,428 03-02-2015, 09:39 PM
  Craigslist find: Not Mine dixieboyz13 3 2,429 01-13-2015, 11:51 PM
  parts for sale broncomatt 3 1,216 08-31-2014, 12:19 AM
Last Post: shon
  Parts Jbass 0 1,433 07-16-2014, 12:27 AM
Last Post: Jbass
  Leftover EB parts ParadisePWoffrD 5 3,867 06-20-2014, 08:14 PM
  Efi 302 in Charleston Crawdad 1 1,319 05-08-2014, 09:19 PM
Last Post: Casey835
  Parts for Sale. Prices added. BucknEB 21 5,401 03-26-2014, 03:22 PM
