Any Thoughts on these Axles?
http://www.tomsbroncoparts.com/product/c...bronco-new
Any thoughts on these axles? seems the prices are all over the board at other suppliers.
Prices probably vary with the warranty offered. I would recommend whatever has the best warranty.
Those are the axles I run in my front end. I only use a powerlok posi front so they are overkill to me. I'm more likely to brake the joint than I am to brake the shaft. A good time to upgrade to full clips on the ujoint too.
I just ordered a set of them from Toms. 370 bucks with shipping and a set of full circle clips. Maybe the first I will order a detroit power locker for the rear.
with the 4sp, detroit aint too fun...lots of popping and jerking in the corners and turns.http://www.quickperformance.com/Ford-9-E..._7996.html <<(is better option)however, thats for a 31 spline. which, if your are installing a rear locker-do yourself a favor and get 31 spline chromo shafts-you will break the stock ones-sucks way worse than breaking a front, cuz then you cant drive home
[Image: e9717df43c6da3074e05f6d4bf408fec.jpg][Image: 7064918edca2b19959ecc6d205480d3f.jpg] Got around to installing the new Twin Sticks today. These are pics of the repaired one which had broke again already. I ground a groove to aid penetration in the new one and welded it up before installing.
Sent from my NEC-NE-201A1A using Tapatalk
Maybe they have an opening for a lead product developer up there.
I'd vote for a Detroit in the back as I don't think you'll be driving this one on the street a lot. 31 spline axles would make nice friends too.
broncosbybart Wrote:Maybe they have an opening for a lead product developer up there.
I vote Detroit with a black spring. drives nice on the road
Dont make the same mistake all of us have made in the past. Suck it up and get 31sp chromos and a decent locker. Do it once and do it right and you will save a ton of money in the long run.
The front Chromolys should be here Monday. Hopefully I will have made up my mind on which/what to do to the rear by then also. Will definitely be going to 31 spline Chromoly back there.
  Bent Axles jdowns67 19 5,556 11-28-2015, 11:05 AM
  Who can CUT and RE-SPLINE axles??? chuzie 11 5,997 08-20-2009, 02:46 PM
  Reinstalling rear axles - help please! jkransbottom 26 4,290 06-27-2009, 07:40 AM
Last Post: Badass
  Chromolly axles cuz1 0 725 08-04-2008, 07:35 PM
Last Post: cuz1
