Hood Scoop
So if you've seen the pictures of my truck, the air filter sticks out about an inch and a half and I don't have the $ for a new hood, wondering if I could use one of the steel scoops from the graveyard and put it on backwards to act as a small cowl, trying to have some sort of temporary protection from the rain. Not sure what the dimensions are for the scoop and if anyone has one, if they like it or not. thanks guys
Could you put on a drop base for your air cleaner?
Take a look at my build thread, the last pics I put you can see a fiberglass hood scoop from Jeffs on there. Its facing backward and there is a hole cut in th
hood for air flow. The air filter base is mounted to a sheet of 1/8" aluminum. Foam about 2 inches thick on the edge of the sheet makes the hood seal around
the air filter housing. The steel one is a new peice, you will have to measure the hole size you need to cut and see if the scoop is wide enough.
Or you can try and find a drop base for the air cleaner, this can be done with a thinner air filter. I felt it restricted my engine too much.
  Hood shocks Timstrk 1 3,166 04-27-2016, 11:08 PM
  Lil Red Riding Hood Build Broncitis 11 6,350 03-04-2016, 12:14 AM
  Hood side bumpers chuzie 8 1,477 10-30-2011, 11:15 AM
  Need advise on cutting a hood cuz1 5 2,498 06-11-2009, 12:07 AM
Last Post: 744x4
