Rebuilding used rear leaf springs
I'm in the process of rebuilding rear leaf springs I bought from Broncomatt many moons ago. Had them sandblasted, primed and semigloss black at this point. Any thoughts as to installing graphite shims or should I just spray graphite in between each leaf?
I would reinstall the pads, if that is what you're asking. If they're gone I'd locate some new ones
I still have some plastic pads in place, a little worn but to me serviceable. I've been reading about tin shims and graphite strips that go through the center bolt hole location. I may be over thinking it and should just spray some dry teflon between each leaf and be done with it.
Its worth getting new pads or making your own. It helps the springs move with out rubbing and keeps them quiet.
I went and ordered 20' of leaf spring liner along with a can of Slip Plate dry graphite lube. If I get a couple of years or more out of this setup I'll be happy. The local vendors wanted $45 just for the liners so hopefully I made a good choice by saving $20 on Amazon. Now I got to wait till the 13th.
Didn't have to wait long as all the parts came on Saturday. Cleaned with alcohol and sprayed Slip Plate in between each leaf. Then added 10' of leaf liner to each pack, should have bought 40' of leaf spring liner but I think what I have will suffice. Added the 6 degree shims, hopefully they are installed per instructions. All I need now is find the bushing and shackles. Check this item off the list!
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 4,679 01-19-2017, 12:53 PM
  Lighted rear view mirror chuzie 6 4,390 06-20-2015, 12:18 AM
  rear main seal snipes243 5 2,788 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 2,261 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 3,528 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 1,848 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 4,172 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 1,432 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 3,469 12-18-2012, 04:52 PM
  Looking for Troubleshooting Tips for a 79' Bronco Rear Window (Powered). UTFLIWGYA 5 4,176 10-29-2012, 05:41 AM
Last Post: UTFLIWGYA
