URE workday Sat March 25
Terry just sent a message, moving the date from the 18th to the 25th. Who all is going to be there? We will meet at 8:30 to 8:45am at the outpost, like usual.
25 works better for me
I'll more than likley be there.
Nick
'73 Bronco - trail modified
Just don't break anything Clay. Windrock is the following week!
So far it is Clay, Nick, and me. Anyone else? Plans are to block off a couple illegal bypasses that started forming last fall. Everything else looked pretty good last month.
I will be there do we need post hole diggers or anything else? I can also bring a grinder and batteries.
I asked Terry to bring an auger, post hole digger, and the drill. Bring your cutoff wheel if you don't mind. Clay should have his too, but it wouldn't hurt to have a spare. Thanks!
If you have a flap disc, put it on your grinder. That way we can cut with one and deburr with the other. I can bring a couple flap discs if you don't have any.
I think I have some but won't hurt to have extra will be able to check when I get home from work after midnight some time
A couple folks riding with me.
I see you all are meeting up at El Dorado. Do you all meet up at Hunt Camp later?
See you guys Saturday
1974, 331 stroker, Holley TA,Dana20 twin stick w/terra low gears, 456 axle gears, detroit in the rear, true track up front ,MSD ignition, 37x12.50 PJs, 9k warn-tabor
Yes, we meet up at the outpost then head down to hunt camp a few minutes before 9. Thanks for posting and see you Sat!
  Sat Feb 25 URE Workday broncosbybart 4 1,976 02-26-2017, 01:57 PM
  January 2017 URE Workday broncosbybart 6 2,344 02-16-2017, 01:47 AM
  Remembering Deborah Walker and Rendezvous Meeting Sat Dec 10 broncosbybart 2 1,308 12-05-2016, 11:47 AM
Last Post: nhopman
  Roll call- Oct 22 URE workday broncosbybart 15 4,704 10-23-2016, 12:13 PM
  URE Work Day - July 16 2016 nhopman 16 4,307 07-18-2016, 10:03 PM
  URE work day- Sat May 21, 2016 broncosbybart 17 4,078 05-21-2016, 09:40 AM
  URE March 19-20, 2016 Work Day nhopman 45 10,704 04-02-2016, 07:20 PM
  Feb 20 URE winter workday broncosbybart 39 9,413 02-24-2016, 10:16 PM
Last Post: mrwarner44
  URE Winter Workday Jan 23 broncosbybart 34 7,398 01-31-2016, 02:02 PM
  Dec 12 2015- URE trail run and Rendezvous Meeting broncosbybart 22 6,396 12-16-2015, 02:34 PM
