mini buildup - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: mini buildup (/thread-1311.html) |
mini buildup - snipes243 - 03-31-2015 Yeah I bought a replacement that I'm going to weld into. mini buildup - snipes243 - 04-06-2015 Got back at it today got the crossmember in, came out not bad at all ![]() ![]() Started getting the pan trimmed up this side is looking a ton better ![]() ![]() Sent from my iPhone using Tapatalk mini buildup - chuzie - 04-06-2015 Nice. Sure hope that bolt hole on the cross member lines up right. ;-) good job dude. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - snipes243 - 04-06-2015 What hole are you referring too, hole guru Sent from my iPhone using Tapatalk mini buildup - chuzie - 04-06-2015 "hole guru" that's what she said! First pic just right of center on x-mbr. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - snipes243 - 04-06-2015 Good eye there hole guru but I don't think she would be to happy since that is the rear hole. The hole won't be used. I ordered a front crossmember and scabed it into the rear crossmember, which was a pain since the channel depth was different. Sent from my iPhone using Tapatalk mini buildup - snipes243 - 04-08-2015 Got the floor pan fitting great tonight just need to finish the rear angle piece ![]() ![]() Sent from my iPhone using Tapatalk mini buildup - snipes243 - 04-13-2015 finally got the passenger floor welded in tonight ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk mini buildup - chuzie - 04-13-2015 Nice welds. Your signature indicates twin sticked dana 20. FIX IT! mini buildup - snipes243 - 04-13-2015 What are you the signature police? Sent from my iPhone using Tapatalk |
