Project Snow Ball - blazinchuck - 09-07-2010 Trey, the 1st one is for an external clip, the second one is for an internal. most caps have the grove for a internal...however if there is a grove on the outside of the housing(H block) then i would use that...ill go see what mine are and report back. Project Snow Ball - blazinchuck - 09-07-2010 heres what it should be Trey. use a socket(that best fits the cap) and press them in far enough to install the clips Project Snow Ball - 73Bronc - 09-07-2010 ok, so I don't need to worry about the internal type. I have been using the external clips. I guess I just need to try one more time and make sure I press the cap in deeper. Project Snow Ball - medwards01 - 09-07-2010 Trey, check that one of the needle bearings hasn't slipped out of place and the grease is holding it sideways in the bottom of the cap....That happened to me once and there is no way in hell to get the clip on with that needle bearing causing interference.... ![]() Project Snow Ball - blazinchuck - 09-07-2010 medwards01 Wrote:Trey, check that one of the needle bearings hasn't slipped out of place and the grease is holding it sideways in the bottom of the cap....That happened to me once and there is no way in hell to get the clip on with that needle bearing causing interference.... dayum, thats probably it...totally forgot that one!!! good call Mike!:xyxthumbs: Project Snow Ball - 73Bronc - 09-13-2010 medwards01 Wrote:I love the look of the side exhaust and tips as well....But, with the exhaust pipes routed between the rear springs and frame rails, won't the pipe get pinched when one or the other of the springs are fully compressed in an off-camber situation? In the picture it just looks like there is not much clearance between spring, exhaust pipe, and frame rail. Am I totally off-base with this observation?.... Mike, you're right about this one :banghead:. Looks like one of the pipes got bent this weekend so I'll have to get them rerouted. I may have to just take them out the back. Project Snow Ball - fomoco - 09-13-2010 Hey TREY where did you find the tips for your exhaust? Project Snow Ball - medwards01 - 09-14-2010 Hey guys, anybody with side exhaust exiting in front of rear wheels have pictures of how they routed the pipes. I am sure Trey would appreciate any ideas....I can't help because mine exit behind the rear wheels.... ![]() Project Snow Ball - firefighter2134 - 09-14-2010 im getting mine done on thursday in front of tires. i will snap some pics and post them this weekend after i get it back Project Snow Ball - 73Bronc - 09-29-2010 Quick update.. I had the exhaust rerouted out the back last week. This week I also tackled the following:
Now, I guess I drive it!! :toothy12: |
