306 EFI build - BucknEB - 01-16-2012 No problem, it was a fun weekend. There's nothing better than hearing that engine fire up after a long weekend spent in the garage. Thanks for letting me test drive it too. Jealousy is an evil sin, damn you ![]() Aside from the minor problems i.e bad fuel injectors, crocked motor mount. I'd say we had pretty good luck on this one. I can only hope that my EFI swap goes half as well. 306 EFI build - SC74 - 01-16-2012 Good to see it up and running again. What upper radiator hose is that? I like how it comes in front of the PS res. rather than through it or behind it. Sounds killler!! 306 EFI build - BucknEB - 01-16-2012 SC74 Wrote:Good to see it up and running again. What upper radiator hose is that? I like how it comes in front of the PS res. rather than through it or behind it. It is the upper Radiator hose for a '68 Pontiac GTO 400cid, then trimmed about 6''-8'' off the engine side. 306 EFI build - blazinchuck - 01-16-2012 the radiator hose makes it!!!!:bdent: shawn came by tonight...and i had to beat on it some:toothy12:...so far i got it to just over 5K rpm.....JUS freakin WOW:eyecrazy: 306 EFI build - shawnboymoody - 01-17-2012 Because Racetruck. 306 EFI build - blazinchuck - 01-17-2012 well...all i can say is the ride into work this morning was awesome! guess i forgot to turn the nice stereo on...musta been enjoying the great exhaust notes being played temp held a perfect 195*...hope that holds true in the warmer days, well have to see 306 EFI build - ncsubronc - 01-17-2012 sounds awesome chuck! looks like you found that 5.0 tone you been looking for! 306 EFI build - blazinchuck - 01-17-2012 yeah, im very pleased with it. i think i nailed the "sound" i was looking for heres a few more pics... couple of the old timing chain, the new timing chain, also the reason i ditched the Tbird fuel rail... interfering with the hard heater hose and sensor. went back to the stock mustang fuel rail 306 EFI build - SC74 - 01-17-2012 That's a bummer about the t-bird fuel rail. I wish I had a schrader vavle to check fuel pressure and could have used it a couple times by now. I was hoping to find one off a t-bird but won't even look now. I have that same hose but didn't even consider clocking it like you have it. I'll look closer tonight and see. What lower hose are you running? I have heard good things about a 7.3L powerstroke lower hose working but have not tried it yet - waiting to replace my radiator before taking my exhaust tubing one off. 306 EFI build - chuzie - 01-17-2012 Get rid of those hard heater line.The ECT sensor can go elsewhere. This will give you the option to have that T-bird rail. |
