* Carolina Broncos 7th Annual NOV RUN @ URE * - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Misc Club Info (https://cb4x4.com/forum-3.html) +--- Forum: Wheeling Events (https://cb4x4.com/forum-16.html) +--- Thread: * Carolina Broncos 7th Annual NOV RUN @ URE * (/thread-3176.html) |
* Carolina Broncos 7th Annual NOV RUN @ URE * - broncosbybart - 10-22-2012 chuzie Wrote:Clay, her name is Fistina! I think Chuck finally got my post in his build thread- [sounds like you've been busy. your EB sounds nicer every post! how hard was that dakota digital setup to install? what tools are required for that? might have to bring some extra tools and a flashlight with me to the URE run ![]() * Carolina Broncos 7th Annual NOV RUN @ URE * - chuzie - 10-22-2012 I knew that was coming. Damn you are predictable! Anyway, I have always had gas in the tank, just a pickup problem. Hope the massive accumulator I installed will prevent that problem this year. Oh, and I have a new battery so no wimpy winch on kodak Sent from my Droid using Tapatalk 2 * Carolina Broncos 7th Annual NOV RUN @ URE * - broncosbybart - 10-22-2012 Well, I mean if you run out of gas every run, you're going to hear about it all the time, right? I'll beat that dead horse. (pun intended) Now the girlfriend thing, I'll leave those comments to everyone else ![]() * Carolina Broncos 7th Annual NOV RUN @ URE * - chuzie - 10-23-2012 Hey man, I reap what I sow! Bring it on. * Carolina Broncos 7th Annual NOV RUN @ URE * - nhopman - 10-27-2012 Just under 2 weeks away - So, who's still wrenching on their junk to get it ready? I got the axle shaft replaced that I broke in Harlan and changed my hubs to original Ford hubs, other than checking fluids I'm ready to roll. Nick * Carolina Broncos 7th Annual NOV RUN @ URE * - chuzie - 10-27-2012 Well my junk is in Charleston collecting tree sap and I am in Tampa untill next Sunday. As usual, I will be down to the wire. Could go as is but I would like to do a few things... Repair rear shock issue Mount ram assist Make bumper somewhat usable Install rock lights Install trans temp sender Install clutch lockup switch I work all that week leading up to URE so I hope to have enough time in the evening to button this stuff up. Sent from my Droid using Tapatalk 2 * Carolina Broncos 7th Annual NOV RUN @ URE * - Bronco Biff - 10-27-2012 Working on a winch bumper.......Hmm, need to order a bettery tray and get some cable.....Right now I'm runnig out to gas up the Truck and get some generator petrol incase Sandy the Frankenstorm slaps us around a little bit!! Just picked up some oil after the boys ball game for an oil chnge in the 4door....need to get the recalled tires replaced also. * Carolina Broncos 7th Annual NOV RUN @ URE * - bronco78 - 10-27-2012 Yes just starting to put new Dana 60 in hope to have it done by then. With my new 42 irocks on it. * Carolina Broncos 7th Annual NOV RUN @ URE * - broncosbybart - 10-27-2012 My rig is waiting on me to use it. Guess I should at least check fluid levels and tire pressures... * Carolina Broncos 7th Annual NOV RUN @ URE * - broncosbybart - 10-30-2012 A little more than a week away!! When are you planning to show up? I'm thinking early Friday afternoon (2 or so). |
