my full width axle build 5/23/07->10/28/07 - krazybronco - 10-29-2007 blazinchuck Wrote:krazybronco Wrote:you know you can fit almost any tire on any truck...just need to cut it out-YO! :lol:blazinchuck Wrote:krazybronco Wrote:homes that is some sick flex and what size tires you running yeah i know but then you have to think of axle strenght i dont think a d28 is going to hold up to 44s my full width axle build 5/23/07->10/28/07 - Exodis - 10-29-2007 krazybronco Wrote:blazinchuck Wrote:krazybronco Wrote:you know you can fit almost any tire on any truck...just need to cut it out-YO! :lol:blazinchuck Wrote:krazybronco Wrote:homes that is some sick flex and what size tires you running It will hold 35's.... ![]() my full width axle build 5/23/07->10/28/07 - 69bronco - 10-29-2007 A little flexy now eh? :twisted: :twisted: She looks good Chuck. Let me know when you take it for a test run I would like to see it in action. my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-29-2007 69bronco Wrote:A little flexy now eh? :twisted: :twisted: She looks good Chuck. Let me know when you take it for a test run I would like to see it in action.Thanks paul! Will do on the invite...maybe this weekend coming,Chuck my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-29-2007 OK, enough with the qoutes!!!! ![]() my full width axle build 5/23/07->10/28/07 - krazybronco - 10-29-2007 ok sorry no more quotes from me my full width axle build 5/23/07->10/28/07 - Exodis - 10-29-2007 blazinchuck Wrote:OK, enough with the qoutes!!!! see what i get for following Krazy... LOL OOps dang another quote :oops: :oops: my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-29-2007 yeah, you gotta watch that Krazy...I hear he's bad news :lol: :lol: back to the topic, if you guys want some flex and cant afford Heims? Get these!!!!!http://www.wildhorses4x4.com/product/Rubber_Degreed_Radius_Strut_Arm_Bushing/front_end I had the frame on the stands high in the air. With the poly bushings and the coils removed, the axle would still sit about 10" off the floor :roll: I install the degreed bushings and the axle dropped to the floor with out the coils ![]() my full width axle build 5/23/07->10/28/07 - fdezone - 10-30-2007 Chuck, besides the obvious exterior cut outs, what sort of trimming did you do to your front and rear wheel wells? Did you extend your rear tubs or do the full-widths help out that much? You can't really tell in the pics because of lighting, but I'm running a 3.5" SL and 1" BL and my 35s in the rear are just inches from making contact with the inner wheel well. (Judging by your signature you got me by 2".) I can trim 'em a little bit more, but not much. Maybe just about an inch or so. If you look closely at the second pic you can just make out the bottom lip of the tubs. I was thinking of lengthening them to remedy the problem. ![]() ![]() I'm nowhere near having your amount of flex. I'll have to check to make sure what it is I'm running, but for only $34.99 you can bet I'll be installing those Rubber Degreed Radius Arm Bushings. my full width axle build 5/23/07->10/28/07 - fdezone - 10-30-2007 HOLY CRAP! Mine are poly, what's left of 'em. JD I presume. I just went ahead and ordered the Rubber Degreed Radius Arm Bushings from WH. ![]() |
