JohnPaul's Build - johnpaulgolf - 01-13-2009 Got the old coils out ... got the old radius arm C bushings out (got a 4* set off my parts truck) ready to install degreed radius arm bushings(still need to order) might need some ext. brake lines front and rear(need to order) ... :rubeyes: have to cut out the old steel sleeve from the rear shackle and install the new bushings and rear leafs also need to pick up my new 9" soon ... :toothy12: Then get at least the powersteering pump in if not all the new pulleys and harmonic balancer ... just don't want to start alot before finishing something else ... ![]() Also I don't know if the F250 shock mounts will go in this time I seem to have some old school front shock mounts that are only about 2" shorter than what the F250 mounts would be ... ![]() Should go quick once all my parts come in ... :popc1: . JohnPaul's Build - johnpaulgolf - 01-22-2009 Allright ... got alot of work left to do but here are some picks ... got one side in the front done ... got the degreed radius arm bushing in and the new front coils ... got my third member put back together now the pick is old ... got my new to me rear sittin waitng to go in ... waiting on ext. brake lines due this friday ... I will up date more soon ... :biggthumpup: ![]() ![]() ![]() ![]() ![]() ![]() JohnPaul's Build - blazinchuck - 01-22-2009 looking good JP...that suspension should work a helluva lot better than before! JohnPaul's Build - chuzie - 01-22-2009 Busy much JP? Gosh dude. Keep it up and your rig may just end up on the trails JohnPaul's Build - jollygrngiant - 01-22-2009 I think you should lift your bronco until you can't work on it in the garage anymore like me!!! :thefinger: Nice work. Keep the pics coming!!:biggthumpup: JohnPaul's Build - johnpaulgolf - 01-22-2009 jollygrngiant Wrote:I think you should lift your bronco until you can't work on it in the garage anymore like me!!! :thefinger: Yeah that would suck ... maybe this spring when I get 40's and 1tons ... but I will be going for the lowest COG as possible ... so we will see ... ![]() JohnPaul's Build - broncomania - 01-22-2009 lookin good jp. mine is next. JohnPaul's Build - SC74 - 01-22-2009 I'm digging the carpet ![]() Looking great - when do you anticipate it being back on the trail? JohnPaul's Build - Timstrk - 01-23-2009 Perhaps some larger jackstands are in order. That looks scary. Tim JohnPaul's Build - johnpaulgolf - 01-23-2009 SC74 Wrote:I'm digging the carpet Should be ready this weekend for a test run ... I wanna make a trip in early Feb. to a sick nasty Mtn. in ALABAMA ... :biggthumpup: |
