what have you wrenched on your bronco(s) today? - chuzie - 09-05-2014 Spent 2.5 hours at Firestone today. The lack of talent we mentioned last night was evident today. Long story short, nothing got done and have to go back Sunday to school these morons on how to properly do their job. Came home and pulled the driver knuckle off because the "lack of talent" sliced my upper ball joint boot. Just snagged a generic 3/4" boot off the HELP shelf from Advance. It was a bit taller than I would have liked, but it will do the job nonetheless. what have you wrenched on your bronco(s) today? - chuzie - 09-07-2014 Tightened all 10 million header bolts. Re-gapped plugs to .050" Found my front right turn bucket has bad contacts. Picked up a pigtail frim Autozone and adapted it to the Bronco bucket. Works great! Worked a clearance issue with wiper linkage and cover. Got my alignment done. Wahoo! Riding on rails again. Sent from my GS3 on Cyanogenmod with T2. what have you wrenched on your bronco(s) today? - broncosbybart - 09-08-2014 Been working like mad. Not much time to snap pics or chat. A few shots of fabbing up a glove box for the stainless dash. what have you wrenched on your bronco(s) today? - chuzie - 09-08-2014 Simple dash design. Nice! Today I fabbed a panel to protect my OBA manifold in the old aux tank filler neck area from mud, rocks, and debris from tire. ![]() ![]() Didn't do much else to the Bronco; was busy doing a lot of overdue mx items on my civic. Sent from my GS3 on Cyanogenmod with T2. what have you wrenched on your bronco(s) today? - chuzie - 09-08-2014 Had a few more minutes so I squeezed in another item from my list. Moved the lever lock from the rear brakes to the front. Just made more sense to have it on the larger calipers. Don't want to pull a Clay on Daniel! Sent from my GS3 on Cyanogenmod with T2. what have you wrenched on your bronco(s) today? - snipes243 - 09-08-2014 chuzie Wrote:Had a few more minutes so I squeezed in another item from my list. Funny man Sent from my iPhone using Tapatalk what have you wrenched on your bronco(s) today? - broncosbybart - 09-09-2014 Is there a way to make a solenoid activate the line lock in conjunction with the neutral safety switch??? what have you wrenched on your bronco(s) today? - snipes243 - 09-09-2014 :twothumbs: broncosbybart Wrote:Is there a way to make a solenoid activate the line lock in conjunction with the neutral safety switch??? what have you wrenched on your bronco(s) today? - chuzie - 09-09-2014 broncosbybart Wrote:Is there a way to make a solenoid activate the line lock in conjunction with the neutral safety switch???Tell u what jerkey. I will rig it that way and we can test it with you standing between my bronco and poser rock! ![]() Sent from my GS3 on Cyanogenmod with T2. what have you wrenched on your bronco(s) today? - chuzie - 09-09-2014 Dumped 15 of my 20 gallons of emergency fuel into the Bronco to "dispose" of it. I treat it for long term storage but 2 years is my limit. Wasn't too happy about dropping $70 on ethanol free gas to refill them though. An ounce of starbrite in each can and good to go for another 2 years. Replaced my HP fuel pump. Also found my spare was bad. :-( Glad I found it now instead of on the trail. Made a hi-lift base. Sent from my GS3 on Cyanogenmod with T2. |
