mini buildup - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: mini buildup (/thread-1311.html) |
mini buildup - broncosbybart - 04-14-2015 Looks good! Get the front shock hoops figured out yet? mini buildup - snipes243 - 04-14-2015 broncosbybart Wrote:Looks good! Get the front shock hoops figured out yet? I my set finally got here, once I get the floors and cage in I will get them in mini buildup - broncosbybart - 04-14-2015 Feeling a little tipsy there are we? Thought the floors are done already ![]() mini buildup - snipes243 - 04-14-2015 broncosbybart Wrote:Feeling a little tipsy there are we? Thought the floors are done already No they are defiantly in, just a little finishing work to do. Gotta find some bed liner to put over them. mini buildup - snipes243 - 04-14-2015 Looking for some decent bed liner to cover my floors with. Any recommendations? Been think that something that can roll would be the best. mini buildup - chuzie - 04-14-2015 I have zero experience but seen it discussed many times on classic. And yes, I am the sig police. I just want folks to know I tap danced on your hood at Tellico because you had an Atlas, not a D20. ;-) Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - scbronco - 04-14-2015 Herculiner. Good prep and prime first. Roll it on. Rock it. mini buildup - Crawdad - 04-14-2015 I've seen UPol Raptor liner applied and it looked nice. It had a smooth surface (not mirror smooth) unlike Rhino liner being very coarse. mini buildup - scbronco - 04-14-2015 My raptor was junk. The kit provided is only enough to put down a thin layer. You would need to buy 3+ kits to get to a durable linex quality bed coating. Plus mine stayed shiny. I've seen 3 year old Herculiner that still looked great. I think cuz it's tolled on it goes down a little thicker and holds up better. When I redo mine it'll either be expensive linex or Herculiner, as much as it takes to get it thick. Note: the linex guy in Lexington said a full size truck bed takes about 6-8 gallons of product. You can do the math on the raptor kits. mini buildup - Crawdad - 04-14-2015 Get with Phoneman, his buddy wikedlester will become a Rhinoliner dealer before too long. |
