ParadisePWoffrd's EB - ParadisePWoffrD - 01-30-2012 Finally got the plumbing finished and everything back together. I put the wheels back on, but still need to get the new lug nuts... Once those come in, I can put it on its own weight and get it over to my friends shop for some tube work... Lastly is trying to refit all the front sheetmetal, or atleast the hood/grill ![]() ![]() ParadisePWoffrd's EB - ParadisePWoffrD - 02-02-2012 I finally was able to get it back on all fours... steering works well and i drove it up the street a little.. still need to make some shock mounts and a new front driveshaft ParadisePWoffrd's EB - blazinchuck - 02-03-2012 cant wait to see this thing in action! ParadisePWoffrd's EB - ParadisePWoffrD - 02-03-2012 yeah i cant wait either... I have talked to one of my chassis builder buddies and I think we are going to start bending up a tube chassis in the summer/fall. Plans are to build it around the dimensions of the current rig with some improvements, and then just swap it all over next winter... This thing has a ton of steel in it and seems strong, but the frame limits where I want it to be... figure a chassis will be easier then cutting up a good bronco... also got a SXS project for the rest of this winter... Ill start a new thread on it once I get this thing all finished up ParadisePWoffrd's EB - ParadisePWoffrD - 03-25-2012 I got some time to add some tube to the front... still need to finish weld it and weld on the shock mounts... then figure out how to hang the front clip back... try to get pics soon ParadisePWoffrd's EB - blazinchuck - 03-26-2012 im ready to see some updates ParadisePWoffrd's EB - ParadisePWoffrD - 04-04-2012 got the shocks mounted... still need to add a few bars for strength... sorry for the crappy pics ParadisePWoffrd's EB - SC74 - 04-05-2012 I am liking that pushed forward front axle! How much total wb do you have? ParadisePWoffrd's EB - ParadisePWoffrD - 04-05-2012 im at 119" right now... I would like to be about 5-10" shorter... currently the front is pretty much where i wanted it... I built the links the length i wanted, but the tranny mount limited how far back they went.... If I get around to redoing the rear suspension, I will shorten it up (maybe)... Now if i can get some sheet metal back on it, so people know its an EB and not some jeep ParadisePWoffrd's EB - ParadisePWoffrD - 04-06-2012 braced the tube down to the frame and tied them across the motor... charged the airshocks and took it for a drive... There is about 6" uptravel up front & 3" in the back... 78" to top of cage.. |
