my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-30-2007 fdezone Wrote:HOLY CRAP! Mine are poly, what's left of 'em. JD I presume. I just went ahead and ordered the Rubber Degreed Radius Arm Bushings from WH.I know you wont be sorry getting those! Also, dont tighten down as far as they will go, just snug enough to get the cotter pin in. It's still tight enough. Right now, I'm barely hitting the straight edges from the inner fender wells. I'm just gonna hammer them over or flat. So far, it's sweet! I feel way better off camber(ditches) with the FW's. Thanks,Chuck my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-30-2007 heres some more pics. I fixed the brakes, the new MC was not working...so I used my old F250 MC I was using for the manual chevy disc conversion I used to run on the EB axle. I set the tow in on the front.Found 2 burned plug wires. adjusted the clutch, releveled the gas tank(was angled down). I tightened the hose from the PS cooler. She is good to go now. All that's left is the inserts and soft doors!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() my full width axle build 5/23/07->10/28/07 - fdezone - 10-30-2007 SWEET! She looks great. my full width axle build 5/23/07->10/28/07 - broncomania - 10-30-2007 got it lookin and workin good chuck. A+ my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-30-2007 I think you and I started about the same time. Yours looks like a trail killer bad A machine. Might take a while , but I'll get there. I just took it for a ride to the store ![]() I will ask them about it before I try to adjust the box,Chuck my full width axle build 5/23/07->10/28/07 - krazybronco - 10-30-2007 blazinchuck Wrote:I think you and I started about the same time. Yours looks like a trail killer bad A machine. Might take a while , but I'll get there. you was there a core charge or anything like that because if there was then you got a differant box my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-30-2007 my box was only 1yr old, I shipped it to them with the pump(for checking) so they could port my box...no core, just flat rate on porting. my full width axle build 5/23/07->10/28/07 - Hotwhlz - 10-30-2007 Great looking truck dude! I got a feeling I'm gonna get to watch some really nice crawlers perform with this group. my full width axle build 5/23/07->10/28/07 - blazinchuck - 10-31-2007 Hotwhlz Wrote:Great looking truck dude! Thanks Ron! my full width axle build 5/23/07->10/28/07 - blazinchuck - 11-03-2007 I was able to take the bronco out to the pits today...sorry no pics/videos ![]() I was really worried about going today. Last night the GDI gang was hanging out, so for entertainment...we hooked the front of the bronco to the front of Shawn's yota. I only had 3 wheels(1 bad ford hub-not engaging)....well, neither of us moved...but Shawn stripped about 6-7 teeth off the front ring gear ![]() |
