File Line Function
/printthread.php 287 eval
mini buildup - Printable Version
+---- Thread: mini buildup (/thread-1311.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
mini buildup - chuzie - 04-14-2015
6-8 gal? Holy crapola batman!
mini buildup - snipes243 - 04-14-2015
The hereculiner is sounding like exactly what I was looking for.
mini buildup - snipes243 - 04-16-2015
Got the everything smoothed out and the patch panel over the tunnel fixed tonight [Image: 059f8710d0cd5649f0b5cfa36ad59193.jpg][Image: 2fe64f7e2251e1d0e58f7cbbeae27b70.jpg][Image: 07eb4ea5f90dd5bfd94a8cfe31c6f59d.jpg]
mini buildup - broncosbybart - 04-16-2015
I would highly recommend you not use Herculiner. It is very coarse like sand paper and adheres poorly. I much prefer Raptor. That said, none compare to a professional liner.
Whatever you decide, be sure to use a high quality primer first. I'm sold on the 2 part epoxy primers. It all gets expensive quickly.
mini buildup - chuzie - 04-16-2015
Bart, in terms of cost effectiveness, is it worth doing the prep yourself and then taking it to a professional for the final spray?
Yes and no. Usually they will charge less if everything is gutted from the interior (seats, belts, etc). They do all the liner prep themselves.
I can only say this for line-x. No idea on any of the others. I'm sure they use a lot of product, as the finish is 1/8"-1/4" thick. As was stated earlier, buy 5+ gals of anything and you've already lost money.
Most people only put down 2 gals of DIY stuff.
Question, should I prime before, I seam seal it?
mini buildup - scbronco - 04-16-2015
I say yes so that all he raw metal is primed
Well finally feel like progress was made. Got the interior primed and seam sealed. Well minus two seams under the driverside floor, so back to the parts tomorrow for more. [Image: 3d99421620482dd3af57202cc876cf65.jpg][Image: 6485c2ecdd688bc32afc9b95cca51ffd.jpg][Image: e561f5644f11ca8e3d1e94a747b0b53b.jpg][Image: 71009874882dd8fcbc2517bf349106e4.jpg]
As for the bed liner still undecided, I'm leaning towards painting it right now and when I get back from telico bed line the whole interior and bed.
mini buildup - broncosbybart - 04-17-2015
Looks nicer than the rest of the truck!
