10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Misc Club Info (https://cb4x4.com/forum-3.html) +--- Forum: Wheeling Events (https://cb4x4.com/forum-16.html) +--- Thread: 10th Annual NovRun@URE '15 **The Big One Zero**TEN** (/thread-3759.html) |
10th Annual NovRun@URE '15 **The Big One Zero**TEN** - wepuckett - 10-13-2015 The update is the check I have been waitting on for the second part of the money to order parts finally arived today so I can order brake lines and fuel lines and clips now. Trying to go over everything I need to get it road worthy but keep feel like I am forgetting things oh yeah need to find a place to install the trans cooler and find or make lines for that as well. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Broncitis - 10-13-2015 Put the trans cooler under the seat and you will have heated seat. Not long til Novrun are U gonna make it? 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - chuzie - 10-13-2015 Are you using the cooler in the radiator? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - wepuckett - 10-13-2015 I am gonna use the cooler I got from Chuck as I have a nice Aluminum radiator I got in one of the deals I wanna use and it doesn't have a auto cooler in it. My mindset is to think I can make it but realistically unsure. I get one more check for parts but it doesn't come till the 1st of Nov so if there are last minute things I can put off till then trying to get as much done as possible might have to make a run to Duff's for parts if I think that is all I would need to finish would rather get parts else where as they would be cheaper but will make that call on the 2nd of Nov. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - chuzie - 10-13-2015 If you have a good fan and shroud on the radiator, you can get away with mounting the aux cooler to the front of the radiator without affecting the engine temp. You ate going to need a pretty high btu cooler if it is your only cooling source. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - wepuckett - 10-13-2015 Can you go in further detail my current fan is the engine fan remember I havn't even thought about the plan of action with the cooler open to all ideas. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - chuzie - 10-13-2015 Absolutely man. Start a new thread and I will be happy to elaborate as I have had just about every cooling iteration known to man, but I don't want to muck up the NovRun thread with a bunch of tech stuff. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - chuzie - 10-14-2015 Hey Chuck, maybe you should bring a spare axle housing, 4 spare shafts and a complete 3rd...just in case Daniel schools your a$$ again! Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - broncosbybart - 10-14-2015 You are the one to talk... 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Broncitis - 10-14-2015 I put a new 15 inch steering wheel on today as the 13 inch I had on it was a handful since I locked the front. With all my antique parts maybe i will just spectate and watch you guys bust those hi performance parts. Nah that would be no fun. |
