what have you wrenched on your bronco(s) today? - chuzie - 04-11-2015 Perhaps the relatively cool dry air damaged my brain. I shall retreat to my man cave, fetch a wine cooler and watch something on Lifetime. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! what have you wrenched on your bronco(s) today? - broncosbybart - 04-11-2015 Have fun romancing the bronco chuzie! Weather was beautiful here today. Did some wrenching and metal fab on the 67 project as well as started prepping for the trip to Tellico. Mainly had to work on the trailer lights and wiring. Only a few weeks away! what have you wrenched on your bronco(s) today? - chuzie - 04-11-2015 I took the day off. Been at it every day since I got home a week ago. All I did was reclock steering wheel, move outer sun visor brackets inboard to prevent hitting the roll bar and tighten the B nut on one of my new trans hard lines that was leaking. I would like to fix my rear pinion leak and fab gas tank armor next week. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! what have you wrenched on your bronco(s) today? - jdowns67 - 04-12-2015 Took my 3G alternator off today to have it rebuilt because it has been intermittently cutting out. Discovered why when I removed it. When I had my new motor installed like 4 years ago, the idiot put the green and red exciter wire to ground so basically it's been charging wide open all the time. Can't believe I didn't fry something. what have you wrenched on your bronco(s) today? - chuzie - 04-12-2015 Wow! I sure hope that idiot is gonna get an ear full from you. The fact it lasted this long is a testament to the quality of some of these parts. What's the rebuild gonna cost? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! what have you wrenched on your bronco(s) today? - snipes243 - 04-12-2015 chuzie Wrote:Perhaps the relatively cool dry air damaged my brain. I shall retreat to my man cave, fetch a wine cooler and watch something on Lifetime. Don't forget to chill your wine coolers, so you don't get cranky Sent from my iPhone using Tapatalk what have you wrenched on your bronco(s) today? - Broncitis - 04-12-2015 Pulled the radiator, Alternator, Water and Power Steering pumps and eyeballed what I will have to do to install the Twin stick. Guess I will have to pull the old J shifter before I can get a good plan on how hard it will be to access the parts with a cutting wheel on the grinder. Hoping the 3 inch B/Lift will make it a lil easiar to get to. what have you wrenched on your bronco(s) today? - chuzie - 04-12-2015 I was able to get in there from the top with a plasma cutter. Not the cleanest but certainly effective for twin sticks. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! what have you wrenched on your bronco(s) today? - scbronco - 04-12-2015 Sawzall might get to it through the hole if ur real careful. what have you wrenched on your bronco(s) today? - chuzie - 04-13-2015 Fixed my rear pinion support leak. The O-ring was fine but the flange that supports the O-ring was chipped. This was likely due to me getting overzealous during a previous install. JB Weld was perfect for this fix. Let it set for 24hrs and cleaned it up with various files. Perfecto! Changed a failing u-joint on the front driveshaft. Lubricated all my joints. Made sure everything was tight in preparation for Tellico. Got a new sponsor. ;-) Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! |
