what have you wrenched on your bronco(s) today? - chuzie - 04-29-2015 This is a hammerlock link with a hook. [ATTACH=CONFIG]8706[/ATTACH] It is used to connect the hook to a chain or rope. They come with a pin that is not designed to be easily and quickly removed thus rendering the link semi-permanent. I want to replace the pin with this to make swapping the hook for a shackle much easier. [ATTACH=CONFIG]8705[/ATTACH] what have you wrenched on your bronco(s) today? - Broncitis - 04-29-2015 I have used these on farm implements but have never them them in grades. I figure all I have seen would be grade 5. Maybe check at a Tractor Ag dealer(John Deere/Kubota). Tractor Supply TSC sales them but not sure what the grade is. what have you wrenched on your bronco(s) today? - chuzie - 04-29-2015 Grade 8 exists but is not common. There is a 5,500lb difference in quadruple shear for gr5 vs gr8 in this application. Checked TSC as well. Going to look up some dealers as you suggested. what have you wrenched on your bronco(s) today? - snipes243 - 04-29-2015 chuzie Wrote:This is a hammerlock link with a hook. Whats the sear strength of those's pins. I would be a little leary put a pin that is only retained by the little strap. What happens when your winch and that little strap comes undone? I use to run a set of the those pins on my door hinges and the little latches always kept popping off. If the pin fell out or back off during winching it might not be a fun experience. Have you thought of using a pin and a cotter key? what have you wrenched on your bronco(s) today? - Broncitis - 04-29-2015 I repurposed a mirror which i took off of the V Rod when i put chrome ones on it. Bracket can be improved but I'll try it this way to see if I want to spend time on a different bracket. http://www.cb4x4.com/forums/attachment.php?attachmentid=8707&thumb=1&d=1430310928 what have you wrenched on your bronco(s) today? - chuzie - 04-29-2015 5/16 gr5: Single: 5,522 Double: 11,045 Quad: 22,088 gr8: Single: 6,903 Double: 13,806 Quad: 27,612 what have you wrenched on your bronco(s) today? - chuzie - 04-29-2015 Just saw the rest of your post. I have considered using a pin and cotter key. Problem is, if I drop the key, I am done. I like the round wire lock mainly because it is attached. It is spring steel, so I can probably tweak it so it keeps more pressure on the pin to prevent inadvertently coming off as you described. what have you wrenched on your bronco(s) today? - snipes243 - 04-29-2015 chuzie Wrote:5/16 gr5: I would be leary chuzie with the grade 8 you have 13,806lbs double shear which has a safety factor of 1.7 for 8000lbs winch. Now if you use a snatch block back to the vehicle you basically double your pull strength to 16000lbs which will have a safety factor of .86 so it will most likely break. FYI when I deal with stuff I like safety factors between 4 and 5. what have you wrenched on your bronco(s) today? - broncosbybart - 04-29-2015 Chuzie- it's called a D ring. They make it easy to change stuff out with. Aside from wire, have never seen a 5/16 anything used for recovery gear. what have you wrenched on your bronco(s) today? - snipes243 - 04-29-2015 chuzie Wrote:Just saw the rest of your post. I have considered using a pin and cotter key. Problem is, if I drop the key, I am done. I like the round wire lock mainly because it is attached. Mine always broke where the red arrow is. Also in rigging equipment those would a big no no, since the pin is not mechanically held in place. |
