mini buildup - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: mini buildup (/thread-1311.html) |
mini buildup - chuzie - 10-14-2015 Nice background music! Nothing you can do besides tearing it apart and rebuilding. It may leak a bit but you should be okay. The duffs stage 2 dual mounts are nice but $$$. I am running the Duffs kit that came with my 4-link so that is not an option for you. I did fab my own lower mounts out of 3/8" square tube and welded to the underside of the axle tube. They are super stout and allowed me to utilize every inch of my M95 shocks. mini buildup - snipes243 - 10-14-2015 Gotta love the radio, actually the box doesn't leak crazy. Mounts wise up in the air I really like these one but I can get ahold of to see if they are still available. http://m.ebay.com/itm/231252103221 Sent from my iPhone using Tapatalk mini buildup - chuzie - 10-14-2015 I stand corrected. Those are more expensive than duffs. Nice product though. Call them and ask if they have and discounted scratch and dent units. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - broncosbybart - 10-14-2015 Home made shock mounts for me. The Duffs mounts seem popular if you don't want to cut the tub up. After seeing the link posted, I would probably still go Duffs as the mounting point is higher. Those are nicer though. It's a toss up. mini buildup - snipes243 - 10-15-2015 Tonight got all the an fittings. Just waiting for the -6 line to finished on Monday. Hopefully on Tuesday it will be back up running. ![]() ![]() Sent from my iPhone using Tapatalk mini buildup - chuzie - 10-15-2015 Looks like you polished that turd real nice; even painted it black. Well done. Keeps us (me) posted; we want to know when you are 100% up and running! mini buildup - snipes243 - 10-15-2015 Haha painted it came that way haha Sent from my iPhone using Tapatalk mini buildup - chuzie - 10-18-2015 The more i think about the shaft movement on that box i feel it may be missing a snap ring. Something to consider investigating before it opens up or crunches if that is indeed the case. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - snipes243 - 10-18-2015 Ok so where would that snap ring Be? Sent from my iPhone using Tapatalk mini buildup - chuzie - 10-18-2015 Here is a diagram for the Sag. It has been many years since I did a rebuild, but I think there is a retaining ring that goes on the stub shaft. Check out this diagram. |
