ParadisePWoffrd's EB - blazinchuck - 06-21-2017 damn, looks rough ParadisePWoffrd's EB - ParadisePWoffrD - 06-26-2017 Haven't had much chance to repair. Found the culprit to the body damage. Apparently the front suspension/axles it pushed to the pass side some, allowing the tire to get into everything. ParadisePWoffrd's EB - ParadisePWoffrD - 11-01-2017 Working to rebuild the front suspension. Started by removing the bent truss and replacing/upgrading it and bracing the inner Cs. ![]() ![]() Sent from my SM-G955U using Tapatalk ParadisePWoffrd's EB - ParadisePWoffrD - 03-10-2018 Question for those still around. How valuable is a factory frame? I am looking at trying to get more travel, which means the frame rails are in the way. Trying to determine if I should cut the rails or build a whole new frame. ParadisePWoffrd's EB - chuzie - 03-11-2018 ParadisePWoffrD Wrote:Question for those still around. How valuable is a factory frame?No one is around anymore. We have a group on Facebook but it's dead too. I've seen people sell frames for under 300. Sent from my SAMSUNG-SM-G930A using Tapatalk ParadisePWoffrd's EB - snipes243 - 03-11-2018 Generally worth more with a title ParadisePWoffrd's EB - Bronco Biff - 03-12-2018 Heyyyyyy!!!! People!!! ParadisePWoffrd's EB - broncomatt - 03-12-2018 I sold my last frame for $100, If your going to cut the original its no big deal. There is a vin stamped on the top of the frame that matches your title. You can also get new frames. I say cut and modify!!! ParadisePWoffrd's EB - ParadisePWoffrD - 03-12-2018 broncomatt Wrote:I sold my last frame for $100, If your going to cut the original its no big deal. There is a vin stamped on the top of the frame that matches your title.Good deal. It's not worth the extra work to save $100 worth of frame. Esp since the factory susp mounts are gone anyway. |
