9th Annual NOVRUN@URE '14 - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Misc Club Info (https://cb4x4.com/forum-3.html) +--- Forum: Wheeling Events (https://cb4x4.com/forum-16.html) +--- Thread: 9th Annual NOVRUN@URE '14 (/thread-3651.html) |
9th Annual NOVRUN@URE '14 - broncosbybart - 11-06-2014 I might be there by then. Something came up and I can't leave as soon as I was hoping. I'd like to be there by 5pm. Biff, I am bringing the soft doors and the door panels that you wanted. Do you need fiberglass door inserts, or do you have them already? 9th Annual NOVRUN@URE '14 - Wickedlester - 11-06-2014 We gonna be later than expected too. Cld be 6 or 7 maybe worse. Phone man and I both got some work to do in am and that's never as smooth as expected.. 9th Annual NOVRUN@URE '14 - Bronco Biff - 11-07-2014 I have a set on the '73 but they are not drilled for the hardware. Is the soft door hardware on the ones you have? I cancelled site 21 and will be on 44 right across from the bath house. 9th Annual NOVRUN@URE '14 - snipes243 - 11-07-2014 I looking between 5 and 6 9th Annual NOVRUN@URE '14 - chuzie - 11-07-2014 I'm looking at NEVER! :'( Sent from my GS3 on Cyanogenmod with T2. 9th Annual NOVRUN@URE '14 - 72_EB_GUY - 11-07-2014 I should make it around 4-5. 9th Annual NOVRUN@URE '14 - snipes243 - 11-07-2014 Loaded ![]() Sent from my iPhone using Tapatalk 9th Annual NOVRUN@URE '14 - nhopman - 11-07-2014 I'd like to be there now!!! But sometime around 5-6ish is more realistic. Hopefully not too much later, just depends on how work stacks up today. Nick 9th Annual NOVRUN@URE '14 - broncomatt - 11-07-2014 You guys have fun out there, take LOTS of pics! 9th Annual NOVRUN@URE '14 - wepuckett - 11-09-2014 Had a great day ridding with everyone, will post the pics up I took later on gotta use the daylight to try and get bronco running first. |
