mini buildup - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: mini buildup (/thread-1311.html) |
mini buildup - snipes243 - 10-31-2015 Grinder and lot of work haha Sent from my iPhone using Tapatalk mini buildup - snipes243 - 11-04-2015 Finally they are in just need to charge the one and attach the reservoirs, and ready for the November run. ![]() Just button everything up tomorrow and nut and bolt the bronco and I'm ready. Sent from my iPhone using Tapatalk mini buildup - chuzie - 11-04-2015 Bout dayum time! Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - snipes243 - 11-30-2015 Well my new and improved steering box showed up. It looks pretty cool hope it works better. ![]() ![]() So I have to get out all the old red ps fluid out of the pump so my new box is covered under warranty. I was thinking about drain the pump filling it up with new fluid. Do this a few times to get the old out. Any other ideas? Sent from my iPhone using Tapatalk mini buildup - blazinchuck - 11-30-2015 I think that would work Sent from my HTC6535LVW using Tapatalk mini buildup - chuzie - 11-30-2015 It will go fast so watch it closely or you will run dry. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - snipes243 - 11-30-2015 chuzie Wrote:It will go fast so watch it closely or you will run dry. Not planning to do it while it was running mini buildup - chuzie - 11-30-2015 Pu$$y Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! mini buildup - snipes243 - 12-04-2015 Well As I was getting ready to start changing my Ps box out I discovered my Arb HD line had tore not sure how that happend. Then while I was removing it, I noticed that the motor mounts were broke. Lucky I have a set of wild horse extreme mounts that I have been trying to put on. So last night I managed to get the drivers side in and bolt up minus the bottom stud. The pass anger side was another story I got the mount in but all three holes are lining up. I think the motor is in the wrong position. Have to look at it tonight. mini buildup - snipes243 - 12-27-2015 Fun project tonight got the lucky 13 led headlights in tonight ![]() ![]() Sent from my iPhone using Tapatalk |
