9th Annual NOVRUN@URE '14 - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Misc Club Info (https://cb4x4.com/forum-3.html) +--- Forum: Wheeling Events (https://cb4x4.com/forum-16.html) +--- Thread: 9th Annual NOVRUN@URE '14 (/thread-3651.html) |
9th Annual NOVRUN@URE '14 - chuzie - 12-30-2014 The frame reinforcement kit from BC is great. I had the same issue as you and it was worth the $ not having to fab something up. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! 9th Annual NOVRUN@URE '14 - wepuckett - 12-30-2014 Sounds like you need to pull the bolt out and make or buy a sleeve the exact width of the frame, then put the bolt back in with a washer on each side so it doesn't squeeze the frame. Sounds similar to one of the options i will have to do if I go that rought for the trans crossmember me and Charles discused while out there. 9th Annual NOVRUN@URE '14 - Bronco Biff - 12-31-2014 Yep. looked at the BC kit. Like the fact that it has the holes for the 4x4x2 swap also. |
