what have you wrenched on your bronco(s) today? - broncosbybart - 01-09-2016 Cleaning up an old C4 to rebuild for Sharon's Bronco what have you wrenched on your bronco(s) today? - snipes243 - 01-10-2016 Spent the day tearing my front and apart to fix death wobble think I found my problem. On bushing Looks to be backwards and the duff arm bushing were toasted ![]() Sent from my iPhone using Tapatalk what have you wrenched on your bronco(s) today? - broncosbybart - 01-10-2016 I got new ones directly from them. They are cheap. Don't know if they have revised the design yet. what have you wrenched on your bronco(s) today? - chuzie - 01-11-2016 Why would they do that? They designed a perfectly flawed consumable item to keep your money coming in permanently. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! what have you wrenched on your bronco(s) today? - snipes243 - 01-11-2016 Yeah I will look into it Sent from my iPhone using Tapatalk what have you wrenched on your bronco(s) today? - broncosbybart - 01-12-2016 I've got some nice stock radius arms if you want to swap yours back out, Chuzie ![]() Got most of the bedliner out of the 77 tub and worked on cleaning up the shop a little. Problem is that there is more stuff than there is space! what have you wrenched on your bronco(s) today? - chuzie - 01-13-2016 No, the problem is you keep buying stuff! Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! what have you wrenched on your bronco(s) today? - Bronco Biff - 01-13-2016 So I finally got around to changing the tranny fluid in the 4door since worrying about toasting it pretty good when I blew the upper radiator hose pulling up Black Mountain at 4200 rpm in low on the was to Murphy. Didn't look too bad but 4 GALLONS OF FLUID?!?!?!? My goodness!!! Glad it was just plain old MERCON and not MERCON V, that stuff is $6.19 a quart here!! what have you wrenched on your bronco(s) today? - broncosbybart - 01-13-2016 Or type F for that matter... 4 gallons sounds like an oil change in the 7.3L. Hope you are set for a while! Bolted the Bilstein shocks down on the chassis for the copper 77. what have you wrenched on your bronco(s) today? - snipes243 - 01-14-2016 Fyi on the duff long arms the head cap bushings are made by daystar. After talking to them we could have harder durometer bushings made. But would require a large order. |
