what have you wrenched on your bronco(s) today? - Bronco Biff - 01-31-2016 Holley's used to have an issue with weak power valves that would fail with a backfire thru the carb and then dump gas down the carb. what have you wrenched on your bronco(s) today? - dixieboyz13 - 02-01-2016 It turned out to be something in the needle valve for the primaries. Pulled it, sprayed it with some B-12 and reinstalled. Changed the oil and she fired right up and purred like a kitten. I cant seem to catch a break though as I was on may way to work this morning and one of my calipers on the F250 seems to be hanging up. On the plus side, if I keep replacing parts at this pace, I will have a brand new truck soon. what have you wrenched on your bronco(s) today? - Broncitis - 02-17-2016 ![]() Sent from my NEC-NE-201A1A using Tapatalk what have you wrenched on your bronco(s) today? - Broncitis - 02-17-2016 ![]() Sent from my NEC-NE-201A1A using Tapatalk what have you wrenched on your bronco(s) today? - Broncitis - 03-11-2016 Fabbing some repair parts for the rt rear body mount on ol Blue ![]() Sent from my NEC-NE-201A1A using Tapatalk what have you wrenched on your bronco(s) today? - wepuckett - 03-12-2016 If you need body mounts, when the frame this tub warner is getting cut the body mounts off it and weld them on yours. what have you wrenched on your bronco(s) today? - broncosbybart - 03-12-2016 Going down to the garage now. Got a list a page long. Hoping to knock at least one thing off of it... what have you wrenched on your bronco(s) today? - Rev - 03-26-2016 Wish I was closer, would love to turn some wrenches on a Bronco. what have you wrenched on your bronco(s) today? - Broncitis - 03-26-2016 Where are you Rev? Theres always something to be done on these ol ponys what have you wrenched on your bronco(s) today? - wepuckett - 03-26-2016 so where you from Rev, glad to see you introduce yourself to the group in the introduce yourself thread. |
