the 72 Blazer - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: the 72 Blazer (/thread-1617.html) Pages:
the 72 Blazer - Badass - 07-01-2009 bucketobolts Wrote:That a twin stick shifter on the NP203?yep made from 2 205 shifters. we usually make the set up out of two 203 shifters. it seems to work good. the 72 Blazer - Badass - 07-01-2009 ![]() awsome ramp score!!! lol ![]() the 72 Blazer - Mill Knob - 07-02-2009 Badass Wrote: Man you are to much:hysterical: :hysterical: :hysterical: the 72 Blazer - Badass - 07-09-2009 So in there rears the axle bearing has no inner race. If your bearings went bad it would score the axle shaft because of the no inner race thing. instead of having to buy new axle shafts they came up with this kit to move the bearing outward a bit and change the location of where the bearing rode on the axle shaft. you basically tap the bearing and housing in the end of the axle tube where the original bearing would be. old bearing repair kit installed in the axle tube without the seal ![]() this is the right side that is still good with the seal still in ![]() the way to remove them (thanks Wendell) is to take the shafts out and run a rod through the axle housing and tap it out from the back. I didnt have a rod or piece of pipe so..well, you know the rods you can pound in the ground to hold up a birdfeeder or windchimes? with the squiggly ends on it to hang the stuff off of? well I cut the squiggleys off and the base and used that. I dont really like birds or windchimes. ![]() put it through from the right side and hit it a few times to release the brearin repair kit ![]() you can see it about 1/2 way out here ![]() here it is ![]() end of axle tube without it in. ![]() I actually had some 12 bolt shafts at Johns and I swapped one out because the one in this had a broke stud. If I got the other shaft I could go back to regular bearings because the shafts I had are not scored up. since I already ordered the repair kit I will just use it. |
