bad reputation - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Web Site (https://cb4x4.com/forum-4.html) +--- Forum: Cut Loose (https://cb4x4.com/forum-18.html) +--- Thread: bad reputation (/thread-1667.html) |
bad reputation - sparkchaser - 07-12-2009 Does it matter if your rep. is disabled?ELWOODS and Mikes says disabled. bad reputation - sparkchaser - 07-12-2009 Badass Wrote:i gave you some rep yo. Hey Eric, does it work the same way on wd? I hope not cause I got 0. bad reputation - broncomania - 07-12-2009 sparkchaser Wrote:Does it matter if your rep. is disabled?ELWOODS and Mikes says disabled.darn disabled bronco drivers with a bad rep. :hysterical: bad reputation - sparkchaser - 07-12-2009 hey ELWOOD, I tried to give you a double shot but it said NO ! bad reputation - Badass - 07-12-2009 it is supposed to be if someone gives good info or tech, you give them rep. if you help someone out they should give you rep. if you think something is funny etc give em rep!!! I got like 13000 on wd. just a way for new folks to check on your standing/ honesty or whatever on the board. if someone causes problems (like jp) give em bad rep. if you get screwed in a deal etc...yep bad rep. you should all give me rep for this awsome post! bad reputation - cuz1 - 07-12-2009 Where do you find your own rep rating? I gave everyone in this thread rep..... bad reputation - ELWOOD - 07-12-2009 sparkchaser Wrote:hey ELWOOD, I tried to give you a double shot but it said NO ! Dangit!!!!I appreciate it! bad reputation - ELWOOD - 07-12-2009 cuz1 Wrote:Where do you find your own rep rating? Members tab at the top bad reputation - cuz1 - 07-12-2009 I have a disabled reputation cratchhe: WTF! bad reputation - ELWOOD - 07-12-2009 Badass Wrote:it is supposed to be if someone gives good info or tech, you give them rep. if you help someone out they should give you rep. if you think something is funny etc give em rep!!! I got like 13000 on wd. just a way for new folks to check on your standing/ honesty or whatever on the board. if someone causes problems (like jp) give em bad rep. if you get screwed in a deal etc...yep bad rep. you should all give me rep for this awsome post! I can't give JP a bad rep..He gave me some cool azz hub caps!! JP rulzzzzzzzzzz! |
