short or bad ground? - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: short or bad ground? (/thread-2147.html) Pages:
short or bad ground? - firefighter2134 - 09-19-2010 so i think that i have traced the short to the steering column. i will pull steering wheel and turn signal switch out along with wiring and see if i can find the culprit. but for now i cant get fuse to blow again..go figure short or bad ground? - firefighter2134 - 09-20-2010 i think that i found the culprit of my problem! bad turn signal switch. i have lost turn signals but not blowing fuses anymore. so hopefully i wont be running in circles... short or bad ground? - jdowns67 - 09-20-2010 Those turn signal switches can cause a lot of problems.. short or bad ground? - firefighter2134 - 09-20-2010 Its a flaming river tilt column. |
