Need help with transfer case install - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Need help with transfer case install (/thread-2285.html) |
Need help with transfer case install - 73Bronc - 08-02-2010 It's hard to know for sure because everything is hidden within the section that sits between the case and the transmission. I'm thinking if I can use the long bolts as guides then at least I'll know that the entry angle is correct and then work on the spline alignment once I get it close enough. I guess it would help to have the transmission in gear when we try it tonight. Need help with transfer case install - 73Bronc - 08-02-2010 Oh, and can someone send over a babysitter to help my wife with my three kids while I continue to wrestle this thing :hysterical: :bdent: When momma aint happy, bronco work is more stressfull ![]() Need help with transfer case install - josephitguy - 08-02-2010 73Bronc Wrote:Oh, and can someone send over a babysitter to help my wife with my three kids while I continue to wrestle this thing :hysterical: :bdent: Chuzie? Can you send the Babysitter? :hysterical: Need help with transfer case install - firefighter2134 - 08-02-2010 mine went together fairly easy had to use bolts to pull it the last inch or so but the rest slid right together. have to make sure you are level with tranny. Need help with transfer case install - snipes243 - 08-02-2010 ratchet straps is how i got mine to line up Need help with transfer case install - SC74 - 08-02-2010 73Bronc Wrote:When momma aint happy, bronco work is more stressfull And drinking beer while working on the bronco while momma aint happy makes her even MORE unhappy! Need help with transfer case install - firefighter2134 - 08-02-2010 true...momma says i drink more than i work lmao Need help with transfer case install - 73Bronc - 08-02-2010 Well, yet another round with no success :banghead: :banghead: We get it about 2 inches away and need to lift the case up an inch or so to get everything level but there's a body support crossing in that spot and it prevents the case from coming up to level. Time to take a break and come back to it. I might just move forward with the body lift, that should give us the clearance we need to level it. All this effort, momma unhappy, no successful install... well, the beer's cold :hysterical: Need help with transfer case install - SC74 - 08-03-2010 what body support? Is it the rib under the tunnel? Need help with transfer case install - chuzie - 08-03-2010 give us some pics of the surrounding areas. are you stock body lift right now? did you put the case in gear and rotate the output shaft to ensure the splines are not an issue when mating? |
