ididit install - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: ididit install (/thread-2533.html) |
ididit install - blazinchuck - 12-26-2010 try reversing the turn signal wires...i bet right now the run lights in the front are using the "brighter" element..which wont draw enough causing the flasher to work...just a thought ididit install - chuzie - 12-26-2010 I had the same problem when I was doing my harness. Just trying to remember how I fixed it. ididit install - berg bronco - 12-26-2010 chuzie Wrote:I had the same problem when I was doing my harness. Just trying to remember how I fixed it. think hard! i tried reversing the wires, but no luck. ididit install - chuzie - 12-26-2010 The hazard and turn have separate flashers. Few quick questions... When was the last time you had turn signals that worked? Do you have power going to the turn signal flasher from the main power (i.e. fuse panel, 12V source)? If so, What color wire do you have going from the turn flasher to the column plug? It sounds as though you are not getting power to the column from the turn flasher. Respond with the info and we can go from there. Also, is your horn working? Seems as though you are either missing a circuit or have an earlier setup that does not incorporate a horn relay. ididit install - berg bronco - 12-26-2010 both flashers work the turn signals worked just like they should before install of the new column I could not find a wire to match up with the "purple"feed wire from the column so i temp. hooked it to the 12v horn wire "this could be my problem" if so what wire do i hook the purple feed wire to? also if my stock column worked with the before mentionedwires in my previous post why would i need a "new" wire for the new column? ididit install - Mill Knob - 12-26-2010 berg bronco Wrote:both flashers work If you don't have the promblem sovled by tomorrow when I get home I will call you and we will talk and see what we can come up with. :biggthumpup: ididit install - chuzie - 12-26-2010 the purple wire may not have anything to do with the turn signal but to be sure I need to know what color wires you have hooked up to the flasher and, in turn, where that wire is hooked into the column. ididit install - berg bronco - 12-26-2010 heres what I got iididit column centech harness black-horn-----------------------------yellow-horn light blue-left front turn-----------------2 light blue-left turn dark blue-right front turn----------------2 dark blue-right turn brown-hazard---------------------------brown hazard purple-turn flasher feed------------------? temp.gray horn power yellow-left rear turn---------------------yellow-left stop green-right rear turn--------------------green- right stop white-brake switch----------------------white-stop switch ididit install - chuzie - 12-26-2010 My first thought is to follow the line from the turn flasher into the column. I would venture to bet it needs to be connected to the purple wire. I will see if I can pull some other data and trace some diagrams for you to be sure of what is going on. I am sure of one thing, that purple turn feed has no business being connected to the horn. ididit install - berg bronco - 12-27-2010 ya I know:bdent:i was just using it for a power source when I unhook it i only have the hazards |
