lowered EB streetrod... - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: McCutcheon Custom Garage (https://cb4x4.com/forum-12.html) +---- Thread: lowered EB streetrod... (/thread-2742.html) |
lowered EB streetrod... - blazinchuck - 04-13-2011 yeah..thats behemoth's rig but im really leaning toward a street rod look...skinny/fats! tub'd out hotrod!!! lowered EB streetrod... - blazinchuck - 04-17-2011 went to a swap meet today and scored a narrowed 9" housing!!! doesnt have any shafts...but i'll get some new ones cut lowered EB streetrod... - broncosbybart - 04-17-2011 cool stuff. i like the direction that you are heading. lowered EB streetrod... - blazinchuck - 04-18-2011 heres a pic of the narrowed nine where should i get axle shafts from...moser? strange? gimme some ideas guys lowered EB streetrod... - BucknEB - 04-18-2011 blazinchuck Wrote:heres a pic of the narrowed nine Dude, that thang is tiny. you check with Whamo. ![]() lowered EB streetrod... - SC74 - 04-18-2011 There's nothing "long" about that axle! lowered EB streetrod... - 744x4 - 04-20-2011 The Blue one that was @ the Super Celebration last weekend used the stock frame but removed all the coil stuff up ft and the top of the A arms were right above the top of the frame.The Rear had a c-Notch cut into it to allow the Ass to drop.I made Robert crawl under it to check it out.You wouldnt have to run that much C-notch if you used a 4 link and some airbags in the rear though.I believe there were no Body Bushings@ all just the frame to the Tub. To bad he was running a Chevy Motor in it,Killed the theme with a SBC in there. lowered EB streetrod... - broncomania - 04-25-2011 blazinchuck Wrote:heres a pic of the narrowed nineboth make good axle shafts chuck. lowered EB streetrod... - blazinchuck - 05-12-2011 Aaron bought the rolling chassis and brought me another frame to build with. so far i removed the coil buckets. still have a lot to remove...gonna be slooooooow process lowered EB streetrod... - blazinchuck - 05-31-2011 still collecting parts... so far i scored a '98 explorer 8.8 with disc,sway bar,and 4.10s just got back from summerville and bought a AOD from a 87 f150. looks brand new...was told it was a fresh rebuild, and hasnt been run since..we will see |
