broken thermostat housing bolt - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: broken thermostat housing bolt (/thread-3066.html) Pages:
broken thermostat housing bolt - chuzie - 02-06-2012 Ummmm... ANTI-SIEZE! broken thermostat housing bolt - blazinchuck - 02-06-2012 brad, more than likely...you will get a base gasket with the adapter plate. you'll reuse your tstat housing with gasket. new intake gaskets. and those valve cover gaskets you need already. or...opt for dougs complete stock set up. saves ya money on the adapter...and get a 4bbl later for the alum intake. also, which ever intake you use...you may have to plug up some used or unused items. broken thermostat housing bolt - blazinchuck - 02-06-2012 also...Parks auto on rivers should have that on the shelf broken thermostat housing bolt - dixieboyz13 - 02-07-2012 Well, Ive got intake, and valve cover gaskets on the way. Also got new t-stat housing, and heater bypass elbow coming since the old ones were so screwed up. Figured while I was paying shipping i would finally get my radiator brackets and rubbers too. Going to pick up adapter tomorrow, its only $17, and a new heater bypass hose. Figured I would do it while its off. |
