* Carolina Broncos 7th Annual NOV RUN @ URE * - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Misc Club Info (https://cb4x4.com/forum-3.html) +--- Forum: Wheeling Events (https://cb4x4.com/forum-16.html) +--- Thread: * Carolina Broncos 7th Annual NOV RUN @ URE * (/thread-3176.html) |
* Carolina Broncos 7th Annual NOV RUN @ URE * - blazinchuck - 07-04-2012 site 15! * Carolina Broncos 7th Annual NOV RUN @ URE * - chuzie - 07-04-2012 blazinchuck Wrote:site 15! THIEF! :thefinger: * Carolina Broncos 7th Annual NOV RUN @ URE * - BucknEB - 07-09-2012 I reserved site 17. HYHD!!!!:chili: Even though my Bronco is still in pieces in Chuck's garage. * Carolina Broncos 7th Annual NOV RUN @ URE * - chuzie - 07-09-2012 Site 16 * Carolina Broncos 7th Annual NOV RUN @ URE * - jdowns67 - 08-18-2012 Gonna try and go this year, for the first time ever! * Carolina Broncos 7th Annual NOV RUN @ URE * - firefighter2134 - 09-03-2012 site 27 * Carolina Broncos 7th Annual NOV RUN @ URE * - 73Bronc - 09-04-2012 Can't make it he weekend of the 11th. Planning to go down the weekend of the 17th. Sorry to miss you guys this year. * Carolina Broncos 7th Annual NOV RUN @ URE * - bronco78 - 09-08-2012 I'm in site #13. don't know what i be in .Redoing the bronco puting in a 60 in the front with 3 link or 4link and 42 iroks. If i don't get done i will be in black one with 37 iroks . * Carolina Broncos 7th Annual NOV RUN @ URE * - jdowns67 - 09-08-2012 Anybody ever used one of the U-haul car trailers for an EB before? * Carolina Broncos 7th Annual NOV RUN @ URE * - chuzie - 09-08-2012 Yep, multiple times. You are referring to the flat trailer, right? It will not work if you tell them that a Bronco is what you are hauling since it is not compatible in their computer system so just pick a different vehicle. I can't use the tire straps they provide since my tires are 35" so I just use 2" wide cargo straps with their trailer mounted ratchets. Make sure you bring the Bronco far enough forward to get a good tongue weight or it will fishtail all to hell. I have hauled my Bronco from Tampa to Charleston and back with zero issues at 70MPH. |
