aftermarket tilt columns? also cruise control - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +--- Thread: aftermarket tilt columns? also cruise control (/thread-3390.html) Pages:
aftermarket tilt columns? also cruise control - chuzie - 02-28-2013 So it is a GM column? IDIDIT? So I assume you are going to need a GM style control switch? Here is a page with all the Rostra control switches. http://www.rostra.com/aftermarket-cruise-control-switches-by-rostra.php aftermarket tilt columns? also cruise control - blazinchuck - 02-28-2013 Jbg is ididit..with ford style blinker and a GM wheel. Duff is flaming river with bolt in blinker...in sure on wheel mount. Sent from my DROID BIONIC using Tapatalk 2 aftermarket tilt columns? also cruise control - blazinchuck - 02-28-2013 new ididit column on the way from jeff's...mild steel, so it has to be painted. still gotta order cruise system aftermarket tilt columns? also cruise control - Casey835 - 03-01-2013 Hey did you see the one that speedway has? It is under $300. aftermarket tilt columns? also cruise control - blazinchuck - 03-04-2013 i did and even found one from southern rods cheaper...but i didnt want to fab up anything or take a wrong measurement...the one from jbg should be a drop in. all the others also came with some type of a double D output shaft which required a $70 u joint. jbg's is splinned like the ford. aftermarket tilt columns? also cruise control - Casey835 - 03-05-2013 oh I didnt notice you had already ordered! aftermarket tilt columns? also cruise control - blazinchuck - 03-05-2013 Hoping it shows up today! Gotta paint it and wire in the cruise control knob Sent from my DROID BIONIC using Tapatalk 2 aftermarket tilt columns? also cruise control - blazinchuck - 03-06-2013 got the new column...looks nice. i was a little aggravated. i called 3 time over a week and a half to confirm all the issues with ididit and which turn lever was needed(ie. GM -bolt in, ford-screw in) they assured me screw in...well, just to be sure i wanted to wait to order the cruise control and switch lever. sure enough, it showed up and was a GM bolt in! right on...id be screwed if i took them for their word and ordered the ford screw in. anyway, got cruise ordered and called jeff's...they refunded me the difference between the ford and GM style...so they gave me back $20 on my card. im happy with that. they need to understand what they sell. got the column painted black last night and loosely ran one wire down threw the column...i will use this to pull the cruise harness down threw column later. aftermarket tilt columns? also cruise control - blazinchuck - 03-06-2013 Sent from my DROID BIONIC using Tapatalk 2 aftermarket tilt columns? also cruise control - chuzie - 03-06-2013 Nice shaft!!!! So is that plug style compatible with your centech / painless? |
