Southern Rods AC kit install..part 1-heater - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Southern Rods AC kit install..part 1-heater (/thread-3392.html) |
Southern Rods AC kit install..part 1-heater - blazinchuck - 03-04-2013 chuzie...i got nothing done today! so there! Southern Rods AC kit install..part 1-heater - broncosbybart - 03-04-2013 Allied bead locks? No, you need the Hutchinson 2pc DOT ones. If you're gonna go, go all out! Maybe if you make it that nice the wife will take it back. It was 'hers' right?? You are gonna have a nice ride when you're done with this thing, even without the wish list! Southern Rods AC kit install..part 1-heater - chuzie - 03-05-2013 Legal beadlocks are for the weak. I love driving 80mph with my fingers crossed that my Allieds don't disintegrate and subsequently force me to be liable for any damage I cause to innocent bystanders! Hell, if the circumstances are right, I could even go to jail. Ya, that's right, I'm a hardcore bada$$! Southern Rods AC kit install..part 1-heater - blazinchuck - 03-06-2013 got some more air vent hose today...those people were suppose to supply some press on washer locks that hold cable on rotary switches but the box show up without them! had to go to hardware store twice to get right washers! got the new column mounted, still waiting on cruise control lever to show up so i can run that harness down into the column. glad i got the broken bolt out for the column upper mount...nice having 2 bolts hold it in now. going back out now to try wiring up most of the rostra cruise unit. maybe tuck some under dash wires up and hopefully mount some under dash vents. i hate when my bronco is down!!!! Southern Rods AC kit install..part 1-heater - chuzie - 03-06-2013 Hey jerkey! Wire my cruise control up too while you're at it!!!! Southern Rods AC kit install..part 1-heater - blazinchuck - 03-07-2013 i am wiring yours in... ....into mine! Southern Rods AC kit install..part 1-heater - blazinchuck - 03-09-2013 Its done! Cruise, tilt column, brake booster, heater and vents. Gotta adjust push rod between booster and master cylinder Sent from my DROID BIONIC using Tapatalk 2 Southern Rods AC kit install..part 1-heater - Bronco Biff - 03-09-2013 Good job, Roller Boy!! Southern Rods AC kit install..part 1-heater - blazinchuck - 03-09-2013 had to readjust the TPS and idle...now its running great. tested the cruise out a few times...its awesome!!!! gonna make traveling so much better. Southern Rods AC kit install..part 1-heater - blazinchuck - 03-09-2013 Got everything done today!! Installed the ididit tilt column, rostra cruise control, new brake booster, and the 1st stage of Southern Rods AC/heater(heat only now). I forgot to get pics of the heater hoses... I came right off heater core and went 90° right threw kick panel, then another 90° up. I don't have the fresh air box on pass side, so I ran hose in that vacant area and routed towards front of motor. The rotary knobs were stiff...a little penetrating oil made them work smoothly. In all the mess I screwed up and put the temp control in the defrost hole and visa versa lol...no crazy bout swapping them now. Over all, I'm very happy...I wish there was more room behind dash. I will say if you take a lot of time and really route your wires up high and tight...I think these hoses will hide up behind dash better. Here are some pics Sent from my DROID BIONIC using Tapatalk 2 |
