'78 F250 - Printable Version
+---- Thread: '78 F250 (/thread-34.html)
Pages: 1 2 3 4 5 6
'78 F250 - bucketobolts - 04-26-2007
Picked up the block and crank today. Won't have time to work on it this weekend. Big Grin I'm still looking for a Performer 400 or Weiand Action Plus manifold. I'm also in the market for a MSD dizzy, 351C/429/460 will all work.
'78 F250 - blazinchuck - 06-14-2007
whats the latest on this build?Chuck
'78 F250 - bucketobolts - 06-14-2007
Got to get over to my buddies to take his A frame apart. Going to pull the the cab, fix the a couple little places, and bedliner the inside. Also going to shoot the chassis with a good coat of paint. I'm going to change all the fuel and brake lines while the cab is off.
Figure if I'm going to make her a keeper, I'd better do it right. 8)
'78 F250 - trkbilder - 06-15-2007
Sounds like you're doing it right. can't wait to see the finished product! Big Grin Big Grin Big Grin
'78 F250 - bucketobolts - 06-16-2007
Check out my rims I scored this morning. 8)
[Image: 114-1444_IMG.jpg]
Also have the short block together. I degreed the cam and have my lifters soaking. Will have the heads on soon. Still need to pull the old engine to see if the pick up is any good. Also need the main bolt out of it with the stud for the rear sump pan. I acquired a Mallory Unilite distributor and an Edelbrock manifold.
[Image: 113-1310_IMG.jpg]
'78 F250 - blazinchuck - 06-16-2007
that is gonna be Bada$$!!!!! :twisted:
'78 F250 - krazybronco - 06-16-2007
the better have a video of this thing doing a burn out after you get that bad motor in
'78 F250 - trkbilder - 06-17-2007
Good ole slotted mags, easy to clean and tough as nails, you can't do much better than that!! Smile Smile
'78 F250 - bucketobolts - 06-23-2007
Picked up a set of Ford Racing valve covers with all the accessories for $45.
[Image: 114-1461_IMG.jpg]
