5.0/nv3550...engine now dies at stops*help* - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: 5.0/nv3550...engine now dies at stops*help* (/thread-3449.html) Pages:
5.0/nv3550...engine now dies at stops*help* - chuzie - 05-13-2013 Did you try using the new IAC we got for Tommy? The old unit in the garage is junk and considered inop. Nick, yours does not die because you have a torque converter. Chucks dies because he is manual and pushes in the clutch and the computer / engine is not bouncing back. IAC is mostly for a cold engine. There is something else going on here. I hope to be back tomorrow night so see ya on Wed. 5.0/nv3550...engine now dies at stops*help* - nhopman - 05-13-2013 Which is why I would stick with the slush box. :thefinger: Just for the heck of it you might try adjusting the screw on the throttle body to hold the butterfly valve open a bit more to see if that makes a diff. 5.0/nv3550...engine now dies at stops*help* - blazinchuck - 05-14-2013 i did try tommys iac...so far i havent had it shut off in 2 days. but you can tell its thinking bout stalling. i have been trying to make it stall but it hasnt. the last thing i did was install a new iac(from tommys) i might unplug the vss and see what it does then for the record...i aint be trying to get no jeep suckas! nick...you been so quiet for months, and this is how you come back??? lol 5.0/nv3550...engine now dies at stops*help* - firefighter2134 - 06-08-2013 do you have egr valve? it may be hanging up.. 5.0/nv3550...engine now dies at stops*help* - chuzie - 06-09-2013 EGR is deleted. I am confident it is a sensor issue though. |
