death wobble - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: death wobble (/thread-3797.html) Pages:
death wobble - chuzie - 08-25-2015 I'm confused now. So you have play in the PS box but everything is in spec according to WH? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! death wobble - blazinchuck - 08-25-2015 what about the tie rod to pitman arm? death wobble - firefighter2134 - 08-25-2015 It's all in spec also. Unless it is just a bad end cause it has no more than 50 miles on it death wobble - chuzie - 08-25-2015 Can u post a hd video? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! death wobble - firefighter2134 - 08-25-2015 It's minimal movement but the castle nut is bottomed out on the drag link. Is there supposed to be a washer of some sorts on top of the pitman arm? death wobble - firefighter2134 - 08-25-2015 It's one of those things how much money do I wanna throw at "stock" buy a drag link and hope it fixes it but if not buy a pitman arm and hope for best. If I end up buying both I might as well go heim joint stering to beef it up death wobble - snipes243 - 08-26-2015 firefighter2134 Wrote:It's one of those things how much money do I wanna throw at "stock" buy a drag link and hope it fixes it but if not buy a pitman arm and hope for best. If I end up buying both I might as well go heim joint stering to beef it up If you go heims call Andy at Ironman fab. Hes build both mine and Charles setup. And they are awesome. death wobble - scbronco - 08-26-2015 Lug Nuts? FWIW, i used RuffStuff hiem steering links... i dig em'... |
