C- Wedge bushings - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: C- Wedge bushings (/thread-3808.html) |
C- Wedge bushings - chuzie - 08-11-2015 I have the same issue with hole elongation on my upper track bar mount. That link didn't work though. Hook it up, I'm interested. When you say ball joints are tight, do you mean the nuts or you actually raised the wheel and tested movement? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! C- Wedge bushings - snipes243 - 08-11-2015 http://www.ruffstuffspecialties.com/catalog/FIXIT.html The ball joints are tight no up and down movement C- Wedge bushings - chuzie - 08-12-2015 So why not just weld on a few gr8 washers? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! C- Wedge bushings - snipes243 - 08-12-2015 chuzie Wrote:So why not just weld on a few gr8 washers? I thought about it, but was afraid the washer would just elongate. It could be worth a try. C- Wedge bushings - chuzie - 08-13-2015 How about a piece of 1/4 (a50)flat stock cut to fit? If you elongate 1/4, you have bigger issues. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! C- Wedge bushings - snipes243 - 08-13-2015 chuzie Wrote:How about a piece of 1/4 (a50)flat stock cut to fit? If you elongate 1/4, you have bigger issues. That would most certainly work too, not sure I have any but I will look around. C- Wedge bushings - broncomatt - 08-13-2015 Many times I have welded a grade 8 washer to fix that, always worked and hardly every wore out faster than the frame. C- Wedge bushings - chuzie - 08-13-2015 If it worked so well Matt, why did you have to do it many times????????? BTW folks, I HAVE ARRIVED. The day has finally come when Matt actually agreed with something I suggested. This is it; I have peaked. C- Wedge bushings - broncosbybart - 08-13-2015 I recall you mentioning a death wobble problem. Are your tires balanced? Air pressure? Do the wedges regardless as they could be in wrong and go from there. If you decide to weld washers to the track bar mount, just weld them in a couple places so you can grind it off and replace them should the need ever arise. C- Wedge bushings - snipes243 - 08-13-2015 broncosbybart Wrote:I recall you mentioning a death wobble problem. Are your tires balanced? Air pressure? The plane is to replace the bushings and weld washers on the track bar. The tires were balanced years ago so they could be out of balance. But they seem to drive pretty smooth. |
