Any Thoughts on these Axles? - Printable Version
+--- Thread: Any Thoughts on these Axles? (/thread-3923.html)
Pages: 1 2 3 4
Any Thoughts on these Axles? - Broncitis - 04-30-2016
[Image: 339cc6400a7e2f7908d82ba7a812160a.jpg]Ain't they purty.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Any Thoughts on these Axles? - chuzie - 04-30-2016
You WILL install full circle clips and you WILL tack those caps or I WILL kick your a$$
[Image: 5691acdd815915e59508b58b7b3365c7.jpg]
1 axle assembled. Next time remind me to pay the 30$ assembly fee. LOL
Full circle clips are on the assembled axle. I destroyed one clip and will have to find one to replace it before I assemble the left side axle. I noticed on the grenaded joint that the weld had pulled the metal out of the cap. Weld did not break but the caps must be cast iron. That is what the fracture looked like. What process are you guys using when you weld the caps. MIG or stick and if stick what rod. I have heard Chromoly has some special welding requirements also. I will try to find some reading on the subject but any good input on the subject is welcome.
In a failure situation like you had, the caps would have been destroyed no matter what. We don't need a perfect weld. The weld is not preventing the cap from pushing out as much as it is preventing it from spinning and walking out as a result.
With full circle clips and a tiny tack you are golden. Just mig it.
Any Thoughts on these Axles? - broncosbybart - 04-30-2016
To weld chromoly the right way, it needs to be TIG welded.
I have not tacked my caps as it would make servicing about impossible. You could use anything to tack weld it.
Any Thoughts on these Axles? - Broncitis - 05-05-2016
[Image: 30fbd71c90e59a8bf01e3c9820c8f198.jpg]
The left front axle is assembled. These new axles and Spicer 760 joints do not go together without some force.
They have not been welded yet but soon very soon they will be.
