Bighorn Build Thread - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: Bighorn Build Thread (/thread-475.html) |
Bighorn Build Thread - blazinchuck - 04-01-2008 buckedupbronc Wrote:Marc You make me look bad I'm not thinking you need any help in that field from Marc:thefinger::hysterical: nothing to it...but,to do it!:xyxthumbs: Bighorn Build Thread - blazinchuck - 04-01-2008 looking great Marc!!! Bighorn Build Thread - Bighorn - 05-22-2008 Finished welding the cowl. Still have lots grinding to do. I cut the front clip off of the 1976 body. No going back now.... Bighorn Build Thread - Bighorn - 05-22-2008 The inner fender skirts were toast. I cut them off and patched the inner fenders and started fitting new skirts on. I hope to have them on this weekend. I'll be cutting the quarter panels off after that.... Bighorn Build Thread - johnpaulgolf - 05-22-2008 Cool...keep up the good work...and keep the pics coming... Bighorn Build Thread - broncomania - 05-25-2008 did you get any more done this weekend ?????? Bighorn Build Thread - Bighorn - 05-27-2008 I've got to get the pictures up. I got the front on and screwed in place. I want to find some replacment fenders and make sure the grill, fenders, and hood line up before I weld it all solid. I also cut out the passenger lower quater out and replaced it. I'll post pictures up as soon as I get some time. Bighorn Build Thread - broncomania - 05-27-2008 cool. Bighorn Build Thread - Bighorn - 06-10-2008 I'm uncut!!! The passenger quarter is screwed in waiting to be welded. The front clip is screwed together waiting on me to test fit the fenders and grill. Bighorn Build Thread - Bighorn - 06-10-2008 I needed to fix the driver taillight corner before replacing the driver quarter. I decided just to use a peice of the new corner versus replacing the whole assembly. It was solid except for the lower third. A little skim of bondo and it should look pretty good. |
