Door pins - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Door pins (/thread-844.html) Pages:
Door pins - jollygrngiant - 07-21-2008 I'm a get to cuttin and make some pins for myself tomorrow when I get off work. I'll post some pics for proof too! ![]() Door pins - jollygrngiant - 07-24-2008 Well, got my pins installed yesterday. (pics to come L8TR) got to go to work! Ended up using 5/16th bolts that were 4 1/2 in. long. The 3/8th bolts were just a hair to big. And the 5/16th bolts are just a hair too small. My ? is, did ya'll drill out the holes in the brackets to make it 3/8ths? Cause I think thats what I'm going to do. Johnski, mudmonkey, do you remember what size you bollts are? Door pins - mudmonkey - 07-24-2008 Yes, I drilled the brackets and used 3/8ths. Be carefull, my brackets had a bronze washer insert that was tricky to drill. Door pins - johnski - 07-24-2008 mudmonkey Wrote:Yes, I drilled the brackets and used 3/8ths. Be carefull, my brackets had a bronze washer insert that was tricky to drill.So did mine. Needless to say, there's no bronze washers in a few of my brackets due to overzealous drilling. Door pins - jollygrngiant - 07-24-2008 mudmonkey Wrote:Yes, I drilled the brackets and used 3/8ths. Be carefull, my brackets had a bronze washer insert that was tricky to drill. johnski Wrote:So did mine. Needless to say, there's no bronze washers in a few of my brackets due to overzealous drilling. [SIZE="5"]10-4!!! [/SIZE]Thanks ya'll |
