I'm getting ready to buy this - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: I'm getting ready to buy this (/thread-913.html) Pages:
I'm getting ready to buy this - Timstrk - 08-07-2008 If you want to weld anything thicker than sheet metal you'll be disappointed. A 110v unit won't have the power you need to make a good weld. It will have to run near maxed out all the time. Do yourself a favor and make another choice. Just like anything, better equipment costs more. Tim I'm getting ready to buy this - SC74 - 08-07-2008 Timstrk Wrote:If you want to weld anything thicker than sheet metal you'll be disappointed. A 110v unit won't have the power you need to make a good weld. It will have to run near maxed out all the time. Do yourself a favor and make another choice. Just like anything, better equipment costs more. If you plug it into a high enough breaker it should be fine. I've welded plenty of things with this same welder and no problem thus far. I'm getting ready to buy this - johnpaulgolf - 08-07-2008 Timstrk Wrote:If you want to weld anything thicker than sheet metal you'll be disappointed. A 110v unit won't have the power you need to make a good weld. It will have to run near maxed out all the time. Do yourself a favor and make another choice. Just like anything, better equipment costs more. SC74 Wrote:If you plug it into a high enough breaker it should be fine. I've welded plenty of things with this same welder and no problem thus far. Dang it...not knowing what to do now...hmmmcratchhe: :rubeyes: cratchhe:cratchhe: :rubeyes: Robert, how's my bumper coming?:notworthy: I'm getting ready to buy this - broncomatt - 08-07-2008 To be honest JP, I would only buy it if he can come down on the price some. A 110v welder will only weld up 1/4" steel, 1/8 stainless on its max setting and only be strong enough (for cages, bumpers,ect) with several passes. I used to have one like that but after a few years of hard use I burned it up. It doesnt have a long duty cycle, I still have a 110v welder (they are portable and work so good with a generator) but I went with a snap on unit (made by miller) but it has a continus duty cycle. A cheap alternitive is a stick welder for anything over 3/8" But for doing allot of fabrication and welds you can trust you should look into a 240v welder. Broncomatt I'm getting ready to buy this - 66bronco - 08-07-2008 i have the same welder. i am using it on my build right now. everyone is right. you do have to watch how long you weld, but if you are going to use it a little bit here and there it is perfect. a 220v is better but work with what you have or can get. i would try to get it cheaper, i bought mine new from northern tool on sale for $450. bryan I'm getting ready to buy this - chuzie - 08-07-2008 I want one too. I have a crappy craftsman mig with two power settings. Whoopie. Wish I could have something that nice. I'm getting ready to buy this - johnpaulgolf - 08-09-2008 Any comments?cratchhe: http://cgi.ebay.com/10000-LB-Winch-10000LB-Waterproof-Wireless-5-8-HP-SB_W0QQitemZ150280153105QQihZ005QQcategoryZ43984QQtcZphotoQQcmdZViewItem :popc1: I'm getting ready to buy this - jollygrngiant - 08-11-2008 johnpaulgolf Wrote:Any comments?cratchhe: Never heard of it! I'd like to find out more about it also. Seams like a to-good-of-a-deal kinda thing |
