JohnPaul's Build - jollygrngiant - 03-14-2009 johnpaulgolf Wrote:I want D60's w/5.13's and ARB's and 114" wheelbase full hydro steering 42's 4 linked 3 speed mini stak T-case ... :hysterical: Who doesn't!! ![]() JohnPaul's Build - johnpaulgolf - 03-19-2009 Got one more piece of metal for gas tank protection ... Took a 1/4" plate and a peice of angle iron to make a gas tank bumper ... ![]() ![]() ![]() ![]() ![]() ![]() ![]() JohnPaul's Build - chuzie - 03-19-2009 DUDE! I have to say you have accomplished more in the last few months than I have in the past 10 years. Who the the fire under your rear end? VERY IMPRESSIVE! JohnPaul's Build - johnpaulgolf - 03-20-2009 Don't have any of the lights hooked up just wanted to se how it fit ... kinda bowed in the center and had to notch out the back of the turn signal buckets ... also need to add a few tabs on the top so I can get a tighter fit where it meets the top of the fenders ... :biggthumpup: ![]() ![]() ![]() JohnPaul's Build - SC74 - 03-20-2009 not a bad fit at all! JohnPaul's Build - johnpaulgolf - 03-25-2009 ![]() ![]() The set includes 2 outer, 1 driver side and 1 pass. side axle for the EB D-44. The NEW Moser Max front axles are 4130 through hardened the full length of the shafts. Compare the size of the ears of the Moser to any other axle available, Combine the size of the ears with the through hardened 4130 and you can understand why Moser believes they now have the strongest D-44 axles available. There is no warranty on axles. ![]() ![]() ![]() :rubeyes: :popc1: JohnPaul's Build - chuzie - 03-25-2009 i think a warranty would be a must considering the experiences some people have had with other shafts. JohnPaul's Build - johnpaulgolf - 03-25-2009 chuzie Wrote:i think a warranty would be a must considering the experiences some people have had with other shafts. ""Combine the size of the ears with the through hardened 4130 and you can understand why Moser believes they now have the strongest D-44 axles available."" ![]() JohnPaul's Build - blazinchuck - 03-25-2009 johnpaulgolf Wrote:""Combine the size of the ears with the through hardened 4130 and you can understand why Moser believes they now have the strongest D-44 axles available.""yeah...lemme drive that junk...then we'll see!:thefinger: JohnPaul's Build - johnpaulgolf - 03-25-2009 blazinchuck Wrote:yeah...lemme drive that junk...then we'll see!:thefinger: In your dreams ... :hysterical: These axles will hold up to any abuse my "itty bitty" 36's and Allieds and all that and a bag of chips. :biggthumpup: |
