10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Misc Club Info (https://cb4x4.com/forum-3.html) +--- Forum: Wheeling Events (https://cb4x4.com/forum-16.html) +--- Thread: 10th Annual NovRun@URE '15 **The Big One Zero**TEN** (/thread-3759.html) |
10th Annual NovRun@URE '15 **The Big One Zero**TEN** - snipes243 - 11-04-2015 Well since it's only a matter of time till some thing breaks. Yes I have been around you jokers for long enough. Let's get let a list of spares everyone has. And if some one needs something post up. I have a spare power steering box and hose. Warn 19 spline hubs Various ujoints Fluids, bolts, wire, connectors Sent from my iPhone using Tapatalk 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - chuzie - 11-04-2015 Front axle shafts Front and rear drive shafts D20 rear output assembly Electric fan 9" yoke Wheel bearings U jounts Locking hub Starter Serp belt Tensioner Fuel pressure regulator Fuel injector Hp fuel pump Lp fuel pump A ton of misc parts. List is too long. If you need something, ask me. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - broncosbybart - 11-04-2015 Trailer for mine, should it give up ![]() I think I'm going to need windshield wipers, but I don't think you were asking that. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Bronco Biff - 11-04-2015 Anybody gotta carburetor? Just got around to dissecting mine that had started acting up of late and then went into total meltdown. New spark plugs, off-road needle and seats and floats installed. Results.......FAILURE!! Looks like I'm wheelin' the 4door!! 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - chuzie - 11-04-2015 You have time. Summit can deliver to you by Thursday Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - broncosbybart - 11-04-2015 I have a new in box Edelbrock. Manual choke. I think it is a 600 cfm. Would have to look at it. Not sure if that helps. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Bronco Biff - 11-04-2015 I'm still wheelin' the 4door!! It has windshield wipers. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - Bronco Biff - 11-04-2015 Thanks, Charles. I reaaly have another that just needs the dust blown off of it. The one that is on the truck had been tuned/jetted for the motor. 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - chuzie - 11-04-2015 Pu$$y! Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! 10th Annual NovRun@URE '15 **The Big One Zero**TEN** - snipes243 - 11-04-2015 Bronco Biff Wrote:Anybody gotta carburetor? Just got around to dissecting mine that had started acting up of late and then went into total meltdown. New spark plugs, off-road needle and seats and floats installed. Results.......FAILURE!! Looks like I'm wheelin' the 4door!! Four or two barrel? |
