Reinstalling rear axles - help please! - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Reinstalling rear axles - help please! (/thread-1587.html) |
Reinstalling rear axles - help please! - Badass - 06-25-2009 no problem Joel, glad to help. come on down in august Reinstalling rear axles - help please! - 66stocker - 06-26-2009 Glad you guys figured it out! Now are'nt you glad you joined this site Joel? Good job Eric, your good people. Reinstalling rear axles - help please! - johnpaulgolf - 06-26-2009 Glad to hear that Joel !!! :biggthumpup: That gasket shoud have been on the outside of the backing plate between the bearings and the wheel mounting surface, but should not cause any issues if left out !!! :xyxthumbs: I just got my "new" axles installed last night and this morning should be on the road this weekend ... :chili: Reinstalling rear axles - help please! - Badass - 06-26-2009 he had it between the backing plate and the axle housing. with it like this the bearing would have had to go through it to seat in the housing. I never touched a 9" so I was going by how he said it went. it would be the inner axle retainer plate gasket ![]() Reinstalling rear axles - help please! - jkransbottom - 06-26-2009 Yeah it's weird. I put it back on where the old ones came off from (that inner axle seal in the picture), but I never thought to check if it would fit over the bearing. I'd still like to know what the purpose of that seal is anyway. Reinstalling rear axles - help please! - Badass - 06-27-2009 Joel I think that piece was supposed to be on the axle before the bearing was pressed on. Im not sure though. Reinstalling rear axles - help please! - Badass - 06-27-2009 you can see it in this pic if you look close I think ![]() |
