Merry F'n Christmas - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Talk (https://cb4x4.com/forum-39.html) +---- Forum: Non Bronco Tech/Talk (https://cb4x4.com/forum-8.html) +---- Thread: Merry F'n Christmas (/thread-2013.html) |
Merry F'n Christmas - Badass - 03-26-2010 i have been havin a rattle out of the two rear doors. i have tried adjusting both the pin and the latch with no luck so her is what i ended up doing i got some 3/8 od fish tank type hose from the local hardware for $.25/ft. i got 30 ft for 2 doors. first remove the sill panel. it just clips on. then mark the split in the seal. remove seal. it just pulls off. i didnt have a fish tape so Nut brouoght me by some 10ga hard wire. i used soapy water as lube and inserted the wire. taped it to the tube and pulled it through keeping it soapy. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() fixed ![]() Merry F'n Christmas - bucketobolts - 03-27-2010 That's using your noggin' for something other than a hat rack...great job! Merry F'n Christmas - Badass - 03-27-2010 this has actually worked great!! the tube is not tight in the WS so it still seals the door well. all this does is add a little stiffer resistance when the door is shut. this woulld work with just about any vehicle with this type weather stripping. Merry F'n Christmas - broncomatt - 03-27-2010 Nice work. Awhile back nissan had a simular problems with the quest. As part of the recall we put a small slice in the door seal and slid a section of rubber hose into the seal. Glad you got yours fixed. |
