Need help with transfer case install - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +--- Thread: Need help with transfer case install (/thread-2285.html) |
Need help with transfer case install - 73Bronc - 08-03-2010 SC74 Wrote:what body support? Is it the rib under the tunnel?Yep, that's right Need help with transfer case install - 73Bronc - 08-03-2010 ![]() I figure the 2" body lift will provide the clearance I need. Need help with transfer case install - chuzie - 08-03-2010 how about loosening the motor mounts to allow the tranny to angle down? You should not have to do this but the other option would be to loosen the front 6 body mounts and use a jack to raise the body enough to get the angle you want for the install. When you removed the case was it difficult to separate and remove? was there a loud pop when it finally came off as though body pressure were being relieve that was resting on top of the case? i cant really tell from the pics but i wonder if there are rub or wear marks on the body and the top of the case would have possibly met? this whole deal with the body being in the way is just weird. Need help with transfer case install - bucketobolts - 08-03-2010 I find it easier to leave the extension housing bolted to the transmission. It makes lining up the splines easier, but removing/installing the top bolts can be a PIA. The 2" of body lift will make the whole job easier. I also cut the top of my tunnel out and made a removable cover. This allows easy access to all the top bolts and linkages, and then I can use my cherry picker through the passenger door to lift and hold the transmission and transfer case when installing and removing. Need help with transfer case install - 73Bronc - 08-03-2010 chuzie Wrote:how about loosening the motor mounts to allow the tranny to angle down? Yeah Chuzie, this is an option that we talked about today. We pulled it off attached to the transmission, which in hind sight is probably the way we should have tried for the reinstall. Since I need the 2" lift to close my hood :hysterical:, I figure I might as well move forward with that and then try it again. Project Snowball rolls on :toothy12: Need help with transfer case install - broncomania - 08-16-2010 if i were closer and had more time , i'd come help you. Need help with transfer case install - 73Bronc - 08-17-2010 I have the 2" lift installed so I'm tackling the case install again tonight. :duel: Need help with transfer case install - blazinchuck - 08-17-2010 good luck, and lets us know how it goes! Need help with transfer case install - 73Bronc - 08-18-2010 Case installed! :chili: :rockon: :party: Need help with transfer case install - SC74 - 08-18-2010 Congrats! I'm sure that's a big weight off your shoulders you've been wanting to tackle. |
